    Results 1 to 11 of 11
    Thread: L92 6l80e
      L92 6l80e
      Evening all,
      I have a 2013 L92 6.2 and I am looking at salvage yard 6L80E transmissions. Is there any difference between the 5.3 and 6.2 6L80E's?
      My search on car-part comes up with both 5.3 and 6.2 are the same application.
      Thanks.
      Mountain Springs, Texas
      As far as I know they are the same physical part but the tune in the TCM May be different.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Thanks for the reply.
      I've done some LS swaps with a 4L60E. It's my first time with the 6L80E.
      Feb 2016
      Lawrenceville, IL
      The 6l80 will physically be the same transmission, however, some came equipped with a slip yoke, and others with a flange for the driveshaft depending on application. Regardless, mixing and matching engine with transmission, you will have to have someone program the computer to accept the engine you're using, and alter the gear ratio and tire sizes that it is seeing.
      visit us on the web at www.bowlertransmissions.com
      Thanks for the info.
      It's going into a Jeep JK so it will be a 4x4 6L80E.
      Yeah both the engine and trans will need to be tuned after the install.
      Mar 2015
      Phoenix, AZ
      Installing a 6L80...what trans mount do I use? Energy Suspension part number or ??? Thanks
      Sep 2016
      Bakersfield, CA
      Sorry to sidetrack the topic, I'm about to order a 4L80E from Jake's in August. Would a 6L80E physically be any larger? I need to cram this into a 1st gen F-body without modifying the trans tunnel. I'm told the 4L80 just BARELY fits and will need 90-degree fittings to do so...
      Thanks!
      http://www.TheFOAT.com/92GTA
      1969 Pontiac Firebird
      w/BP 461ci stroker kit, 670 heads & XE274H cam. Primer black with black interior.
      Aug 2010
      Los Angeles
      The 6l80 is much bigger and you'll need to modify the tunnel for it definitely.
      Sep 2016
      Bakersfield, CA
      Quote Originally Posted by spacepirate View Post
      Ok, thanks!
      Sep 2013
      Oakley, CA
      Quote Originally Posted by sginphx View Post
      I used ENS-3-1142G from Summit for the trans mount for a 70 Camaro.
      69 Camaro LS3/6L80e
      70 Camaro RS LS3/6l80e
      74 Nova 434 SBC
      Mar 2015
      Phoenix, AZ
      The 4l80 will fit with banjo fittings.
      Thanks for the help with the mount!
