      Jan 2010
      Pine Plains, NY
      Front Drive assembly 2015 LSA GM
      Front Drive assembly with A/C compressor and 2 wire Alternator for sale. This is off of a crate motor from GM and I can’t use the drive assembly for my Detroit Speed subframe / 68 Camaro. 950.00 plus shipping. Assembly is still on motor as shown in pictures - I took the one tensioner wheel off to get to one of the bolts to lift the motor out of the crate . Also attached is the two kits from SD that show the GM prices.
Size:  144.9 KBName:  57263585903__6010D860-BD82-4228-B020-0BB063F3C2CA.jpg
Size:  103.2 KBName:  57263586812__59679EC7-5B75-456B-B323-988E8CC7E8D5.jpg
Size:  132.3 KBName:  IMG_5530.jpg
      Apr 2014
      JAPAN
      Country Flag: Japan
Size:  332.0 KB My motor is broken here. I would like to swap lsa to 70 camaro. Can I use this part?
      Jun 2016
      I will follow up as soon as I get home and check my LSA. The assembly is still mounted and I’ll check
      Jun 2016
      You can see from my picture that the part of the block that was hit on yours is not used. I would check the forums to see if this would fit with your subframe.
      Apr 2014
      JAPAN
      Country Flag: Japan
      Quote Originally Posted by nickburns31 View Post
      Thank you but I am not an original frame. I also have a rack and pinion.Name:  IMG_3189.JPG
      Jan 2010
      Pine Plains, NY
      You would just have to do some research to see if this would fit -
      Apr 2014
      JAPAN
      Country Flag: Japan
      Quote Originally Posted by nickburns View Post
      It seems not to be installed;(
