    Results 1 to 9 of 9
      Ontario, Canada
      Car not low enough. Please Help
      I hope someone can help me with this one. I installed Hotchkis 1.5" lowering springs on the back of my car as well as Edelbrock boxed control arms with Poly bushings. On the front I have 2" lowering spindles and I rebuilt the front end with poly bushings.
      I always thought the chassis did not sit as low as I intended, but figured once I got the weight of the body on it it would drop a bit lower. Well last night put the body back on the frame, everything except the hood, but the car still doesn't seem to have dropped as much as I expected.
      Could the fact that I tightened up the control arms and A - arms when it was a bare chassis on jack stands have something to do with it? Could the poly bushings be binding or something (I have lubed all the grease fittings)?
      Any help would be appreciated.
      Jul 2002
      Mesquite, TX
      If you put a chevy engine in it, it'd sit low enough (just kidding... sorry, I had to).
      It's entirely possible that your bushings are indeed binding. They should be tightened with the weight on the car (but it's an easy fix - loosen them, bounce the car a couple of times, retighten).
      Ontario, Canada
      Listen don't make me sick Roadrage on you. LOL.
      I figured that may be a fix. Thanks I will try it out.
      Nov 2004
      NW Arkansas
      I agree with derek......loosen all bolts bounce car several times then retighten..........
      *Edit*
      Sorry NG I guess we were posting at the same time
      It may also settle a bit over time as you drive it too. I've seen guys get too aggressive and end with the car too low.
      jp
      ​John Parsons
      Mantorville, MN
      ...car too low.
      Is that possible??? :D
      Nov 2004
      NW Arkansas
      Quote Originally Posted by Derek69SS
      not in our shop
      Well ... I like low cars as much as the next guy, but of course they can be too low. Bad suspension geometry, dragging headers, rubbing tires, etc. etc., are all symptoms of an "overslammed" car.
      Or if one is trying to get a certain stance and one end of the car ends up too low ...
      jp
      ​John Parsons
      Dec 2003
      lost
      dragging headers, etc. etc., are all symptoms of an "overslammed" car.
      jp
      Hey.... I resemble that remark.
