      Feb 2013
      El Dorado Hills, CA
      Question on T56 speed sensor
      I have an LS3 with early 24x crank and 1x cam sensor ECM. When I come to a stop my idle stays up around 1200 rpm for 2 to 5 seconds before it drops to the normal idle. Does anyone know if a bad speed sensor in my T56 transmission can cause this to happen? Runs runs fine otherwise. Thank you!
      Do you have a VSS signal from the trans to the ECM?
      You might try the guys over LStech.com. They good at helping out.
      Feb 2013
      El Dorado Hills, CA
      Should I assume I have a signal if my speedo is working fine??
      NJ
      Are you using drive by wire?
      Feb 2013
      El Dorado Hills, CA
      2001 version; 24x cable throttle
