    Results 1 to 20 of 24
      Jun 2015
      Carlsbad
      II Much Vent System install problem
      Hey guys, the II much vent system uses a -6an ptfe hose which should be connected back to the fuel tank vent port. I have Ricks restomod stamped steel tank that has barbs on the tank for the vent, not a an fitting. Wondering if there is any other way to hook this up besides drilling into a new tank to add a an fitting. I looked around for some kind of adapter without much luck. Seems like there would be a solution for this since barbs are pretty common on fuel tanks. Anybody else run into this problem?
      Cheers
      Dustin
      Oct 2014
      DFW, Texas
      I would likely just a -6AN to barb fitting on the vent and regular fuel hose to Rick's vent. I personally do not see PTFE hose as a requirement for that application.
      You won't find something that will go on that barb on the tank and accept a PTFE 6AN directly.
      1976 Dodge D100 - Warlock
      2016 Subaru WRX - E30 Tune
      Arizona
      You can use the new nylon 3/8 fuel hose like they use on newer cars, and then get a push lock AN fitting, heat the hose and shove it on....
      Jun 2010
      Deployed
      The threaded port on the tank is 1/4” NPT. Buy a NPT fitting to -6 AN adapter. No modifications to the tank required.
      1970 Camaro/DSE build
      Jun 2010
      Deployed
      Jun 2010
      Deployed
      Quote Originally Posted by ddavisart View Post
      I have owned 3 ricks tanks and none of the have “barbs” all have 1/4” NPT. threads.
      - - - Updated - - -
      I have owned 3 ricks tanks and none of the have “barbs” all have 1/4” NPT. threads. Pics please.
      Jun 2015
      Carlsbad
      There is no threaded ports on my tank, just barbs for a push on hose. Just like this one. Barbs at each corner.
      Thanks for the quick replies
      Cheers
      Dustin
      Jun 2010
      Deployed
      That’s not barb lol. That’s a nipple. I would use a quality hose for that. They do sell AN fittings with -6 female to barb for the vent side.
      Second option is Rick does have filler necks with 1/4” npt bungs welded in them. You could run the vent from the filler neck. I however would use a normal fuel grade hose.
      That tank is designed for an OEM venting hook up
      Jun 2015
      Carlsbad
      Barb, nipple...all the same to me, they all need a slide on hose . I think i'm going to pickup one of those push lock to an fittings and just run a small section of hose for it. Would of been nice to keep it 1 line, but this seems like the best option at the moment for me.
      Thanks guys!
      Cheers
      Dustin
      Replace the Teflon hose with Holley Vaporguard hose. It will slip right over the nipple.
      Jun 2015
      Carlsbad
      I like that idea, thanks!
      Cheers
      Dustin
      Jun 2010
      Deployed
      Looks like regular fuel grade hose to me...Seems expensive!
      No it has a liner to prevent fumes normally associated with braided fuel lines. It also will not degrade in a year or two like the braided stuff does. Worth the cost imho....
      Newbury Park, CA
      Oct 2014
      DFW, Texas
      I feel like today's braided is better than it was just a few years ago, most everything now is E85 rated and doesn't seem to have that issue.
      If it doesn’t have a liner it most likely still sucks. I’ve seen no data to indicate otherwise. Post some up if you have.
      Beach Park IL
      Phenix had E85 AN hose that was made of Viton and it was spectacular but is currently unavailable.
      I have been using Parker pushlok hose with the cloth overbraid for fuel vents and pvc routing and it has held up well.
      Donny
      SAE 30 R14 will outgas fuel vapor if its used with compatible fuels, and it will degrade and outgas even more vapor if its not. Generally speaking, anything thats advertised as fuel line but is flexible is going to outgas and degrade to some degree depending on the fuel used. Fuel tank venting is obviously a low pressure application, so its tempting to go the inexpensive route in this area -- this can be problematic if controlling odor is a concern, and it can be dangerous if the vent system is installed inside the vehicle in terms of toxic exposure to gasoline fumes and fire risk. I would not use anything but steel hard lines or PTFE conductive core. Adapting to the nipple/barb is problematic in some cases as the industry really hasn't standardized in this area. Currently I see the gamut of SAE O-Ring Ports, SAE Quick Connect, NPT, various plain steel tubing diameters, all of which require a different method to convert to PTFE or hard line. Flexible rubber type hose is very attractive given this, but should be avoided.
      Hose suppliers are increasingly listing SAE specs, but don't typically explain them. This is a problem as most parts of the US are going to have fuels that have 10% or more of ethanal or other additives and this may increase to 15% with recently announced changes by the president. If you look up the SAE standard you will find hose like Carl pointed to will outgas with 5% additive even though its meets the criteria. The utility of the hose will rapidly degrades at 10% or higher additives -- see below. There is a LOT going on with respect to modern fuels and their effects on vintage cars. I'll be writing about this on the II MUCH Blog.
      "Hose which may be supplied either coupled or uncoupled for use with gasoline, diesel fuel, lubrication oil, or the vapor
      present in either the fuel system or in the crankcase of internal combustion engines in small engine applications. Exposure of these hoses to gasoline or diesel fuel which contain high levels, greater than 5% by volume, of oxygenates, i.e., ethanol, methanol, or MTBE (methyl tertiary butyl ether), may result in significantly higher permeation rates than those listed for 30R14. "
      Name:  Screen Shot 2019-01-16 at 11.34.04 AM.jpg
      Regarding the Earls/Holley Vaporguard product, they don't appear to list compliance with any SAE standard but they do offer this
      "Vapor Guard’s secret is in its layers. The innermost Primary Barrier Layer offers high resistance to heat and aggressive fuels. The middle Vapor Guard™ Barrier is a Thermoplastic layer that provides superior fuel isolation and virtually eliminates vapors from escaping through the hose."
      Notice they are not saying it eliminates vapors, and without characterizing "virtually" its unknowable how much vapor the hose may outgas under different blends or conditions. I'd love to know this information as it looks like an attractive product otherwise.
      Quote Originally Posted by GoodysGotaCuda View Post
      Just because a product's description states E85 rated, doesn't mean it will actually meet your needs. There is a tendency in the aftermarket parts business to rubber stamp "E85 compatible" without specifying any sort of criteria to which it is compatible.
      Newbury Park, CA
      What John states is why we both recommend PTFE for flexible lines. The current line of Goodridge hose and fittings is worlds better than anything I've ever used. It can be cut and the ends installed in the car with just two wrenches and zero blood. By far the easiest fittings to install that I've tried.
      If the nipple on the tank does not accept a PTFE hose an AN6 threaded connection can be welded on. A conversion compression fitting may work if the nipple is free of coatings, smooth, round, and the correct diameter. It would be worthwhile to put some air pressure in the tank and use soapy water to check for leaks before installation/putting fuel in the tank.
      The Camaro has had PTFE lines since 2002. The garage is well sealed and there is zero fuel odor.
