Thread: EFI Pontiac Help
12-08-2005 #1
EFI Pontiac Help
I am considering building an EFI 400 Pontiac.
Here is what I have thought so far;
Stock block, ARP main studs
Stock crank, SRP rods, ARP Bolts,
Hyperutectic pistons, 9.5:1 compression
Edelbrock Performer Heads Ported and matched as needed by Pro
Edelbrock EFI intake, either The Victor or super victor Ported and matched as needed by pro
Throttle Body about 800 cfm. Not sure on injector size,
Cam, Unsure of I am thinking it will be a hydrulic flat tappet.
This would go in my bird, and would be backed by a TH200r4 tranny, mild lock up stall converter, and 3.42 gears.
The needs for the motor is to run good from 2000 to 5000rpm in a street driven car. Good pulling power, tourqe motor.
I have never built a pontiac motor, so I am a little unsure what to go with, all I see are Ram air repop cams.
12-08-2005 #2
- Sep 2004
- Kettering, OH
- 537
Call one of the Pontiac builders like Kauffman Racing. They helped me do the long block on my EFI motor and dynoed it with me. I have a lot of details about my setup on my website.
An 800 cfm TB will be small for ported heads - you'll want at least 1000 or perhaps 1200. You should also consider port matching the intake yourself - it's pretty easy to do.
John1967 Firebird Convert, Fuel Injected 462 ci, TKO 600
12-09-2005 #3Well, I got a good friend that is a pro porter, and he always takes care of me on that.
Bigger TB, wow. I wouldn't thought that.
I'll look at your site for ideas!
12-09-2005 #4Do you have an updated pic of your ride?
12-09-2005 #5
- Feb 2005
- Indianapolis, Indiana
- 337
