    Results 61 to 80 of 93
      Sep 2017
      Forming the outboard passenger and driver side panels
      How the rear trunk panels were fabbed up.
      Pic of a fresh piece of 16 gauge sheetmetal. Next is the dies i made for rolling the flange. Next is the flange that was rolled on the sheet.
      Sep 2017
      Fabbing the trunk hinge support bracket
      Sequence on making the trunk hinge support bracket.
      First is the cutout.
      2rolling the flange
      3 stretching the flange to make it fit contour of inner wheel well
      4 bending the 90 in the brake
      5 what it looks like after the flange and the bend are done
      6 cut hole for radius die
      7 after using the radius die
      8 fit in place
      9 finished piece
      Pic of the finished piece and fitted in place
      Nice looking tank, great job!!
      Sep 2017
      Completing The Trunk Panels
      Completed trunk panel in place
      Sep 2009
      Wow, the metal work is amazing!! Nice work guys.
      Feb 2016
      SoCal
      Hey Hotwheelz. Can I ask you not to post up any more updates? My level of jealousy is through the roof right now and I dont think I can take anymore pictures of perfection in every way possible. The amount of work that went into the sheet metal is truly driving me crazy. Thanks for understanding!
      1970 VW Bug - Just your average mid engine Bug
      Track toy - 06 Evo - E85 and lots of boost
      Newest track toy - 2021 Supra
      Sep 2017
      Howdy Folks! we're Back with updates!
      The Tranny Tunnel:
      The fabbed up tunnelName:  Tweaked and Fitted Funnel to the Tunnel.jpg
Size:  222.0 KBName:  Fitting the Funnel to the Tunnel.jpg
Size:  224.5 KBName:  Fitting the tunnel.jpg
Size:  173.8 KBName:  The Fitted tunnel.jpg
Size:  224.1 KBName:  Tranny Tunnel Bell.jpg
Size:  242.5 KBName:  Pre Tranny Tunnel.jpg
      The fitted, One piece from rail to rail tunnel funnel:
      Sep 2017
      Cabin Floor Work
      Time for the cabin floor! first is removal of the floor between the rails. we will be fabbing and locating the exhaust, brake line ans fuel line hangers, the drive shaft and loops and locating the real-estate these and other items will occupy.
      Sep 2017
      The Rear Axle
      The rear axle and Brake setup:
      Mapleton, IL.
      Nice Build. The fabrication skills are over the top.
      Jul 2011
      Colorado high country
      Yes, really nice fabrication skills and a beautiful build! Thanks for the continuing updates! And I'm also envious!
      Sep 2017
      The Rear Axle At Full Suspension Compression
      Name:  Axle at Full suspension compression.jpg
      Sep 2017
      Fabbibg the rear axle hump panel and driveshaft tunnel
      Name:  Rear panel ove rear axle.jpg
      Crossmember above axle. Made from 16 gauge. Had to make a bulkhead to pass the fuel lines thru from fuel tank
      Name:  Crossmember over rear axle.jpg
Size:  295.2 KBName:  Drive Shaft Tunnel.jpg
Size:  257.8 KBName:  Port side View of Drive Shaft Tunnel.jpg
      Sep 2017
      Cabin Gets A Floor!
      A rear crossmember was fabricated to go up and over the drive shaft and fit under the tunnel.
      The floor pans are fitted and will be installed after we install the exhaust system and hangers, drive shaft loops, seat support cross members, lines and pipes and whatever needs mto be under there.
      Sep 2017
      Very nice fabrication work
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
