    Results 41 to 60 of 93
    1. #41
      Sep 2017
      And ShaZAAMMM! What those mounts will hold in place!
      Mike said”Hung the rear axle housing today for a test fit. Everything looks good so far”
      What Mike said and many more pics to come shortly!
    2. #42
      Sep 2017
      B-Forged Wheels Arrived!
      B-Forged Wheels arrived so we wanted a sneak peek. Wheels are wider than the depth of the inner wheel houses so we have some whilltin to do for ride height pictures with tires.
    3. #43
      They look good!
    4. #44
      Sep 2017
      The Trunk and Wheel Houses
      Here's a pic of the DSE inner wheel house cleco'ed and vice gripped in place.
      The second pic is a fabricated panel, it has issues so we will try again.
      The third pic is the underside view of the panel.
    5. #45
      Sep 2017
      New passenger side trunk floor side panel
      New passenger side trunk floor side panel and DSE inner tub cleco install and driver's side metal removal.
      More detailed pictures to come tomorrow.
    6. #46
      Feb 2014
      Nice work!
      Are those rubber bushings in between the eyelid of the coilover and spacer(1'st pic)? Are they from ridetech? thanks!
    7. #47
      Sep 2017
      Yes, Mike has fabrication skills!
      All the bushings on the rear suspension came from TCI as this is the 2 link torque arm suspension from them, they supplied the shocks as well.
      I will look at the shocks and see what the sticker says.
    8. #48
      Feb 2014
      Quote Originally Posted by HotWheelz View Post
      Thanks!
    9. #49
      Sep 2017
      Forming the outboard passenger and driver side panels
      How the rear trunk panels were fabbed up.
      Pic of a fresh piece of 16 gauge sheetmetal. Next is the dies i made for rolling the flange. Next is the flange that was rolled on the sheet.
    10. #50
      Sep 2017
      Fabbing the trunk hinge support bracket
      Sequence on making the trunk hinge support bracket.
      First is the cutout.
      2rolling the flange
      3 stretching the flange to make it fit contour of inner wheel well
      4 bending the 90 in the brake
      5 what it looks like after the flange and the bend are done
      6 cut hole for radius die
      7 after using the radius die
      8 fit in place
      9 finished piece
      Pic of the finished piece and fitted in place
    11. #51
      Sep 2017
      Driver side outboard trunk panel in place
    12. #52
      Sep 2017
      Drivers side (Port) trunk panel and trunk hinge bracket flange
      Drivers side (Port) trunk panel and trunk hinge bracket flange:
    13. #53
      Sep 2017
      Drivers side Wheel house repair
      So 2 places on rear passenger side outer wheel house needed to be cut out and replaced. The small section at the rear, shown in the first 2 pics, and a large section on the front.
      Last pic shows the front welded in place and some grinding done.
    14. #54
      Sep 2017
      Building The Fuel Tank
      Pictures of the tank being built and of the tank sitting between frame rails. Trying to keep it out of site from a casual glance, by mounting it so it doesn't hang lower than the bumper or lower quarters. The cardboard box is propped up tight to the quarters and the tank is sitting on the box. This is where it will be when the tank is mounted in place
    15. #55
      Sep 2017
      A Few More Pictures of the Tank and Sender
      The Sending unit is from Tanks Inc.
    16. #56
      Sep 2017
      The Tacked Up Tank In Place Between The Rails
      The tacked up tank in place.
    17. #57
      Dec 2019
      Looking really nice. I really like the trunk floor with the bead roller design. Looks good!
    18. #58
      Sep 2017
      Fuel Tank All tacked together.
      Fuel tank all tacked and ready to be back-gassed and welded.
      - - - Updated - - -
      Quote Originally Posted by Lewie415 View Post
      Thanks!
    19. #59
      Nice looking tank, great job!!
    20. #60
      Sep 2017
      Completing The Trunk Panels
      Completed trunk panel in place
