      Feb 2008
      1969 Camaro - LS3 TKO 600 Flaming River R&P
      Researching my LS Swap and (I think) I have most "big" items sorted out..although I have a couple questions i cant seem to resolve after hours of searching.
      Car is currently running a ZZ4 with a TKO600; both a VERY low miles. Flaming River manual rack and pinion steering.
      I am looking at the following:
      - LS376..most likely 480. Was going to go 525 but seems the 480 is better street manners
      - Car has stock subframe but has a Flaming River manual rack and pinion steering
      - TKO600 transmission is virtually new, so will re-use.
      - Holley/Hooker Blackheart Engine mount brackets
      - Holley/Hooker Blackheart clamshell engine mounts
      - Holley/Hooker Blackheart 1¾” mid-length headers
      - Holley/Hooker 302-2 oil pan
      Two questions right now;
      - will the above work with the Flaming River R&P? I'd rather not mess with this setup as it is also new and works well.
      - what transmission x-member can be used with the Hooker mounts?
      Any advice will be appreciated.
      Jun 2010
      Deployed
      Quote Originally Posted by wickster1965 View Post
      If you're using Hookers mounts, look into their crossmember. Its hard to say if your R&P will cause any issues. Where is it located?
      1970 Camaro/DSE build
      Feb 2008
      Hooker does not have a crossmember for a TKO...hence the problem.
      Here are a few pics of the rack (rear mount).
Size:  233.2 KBName:  20181109_232012.jpg
      You are not likely to find anyone here running that rack conversion. There is a couple guys over on Camaros.net with Holley and TKO. Post your questions over there.
      Jul 2016
      I have the Holley mounts and Hurst Driveline x member, LS3/TKO 600. (NO R and P set-up). Only problem is with exhaust clearance. I'm using the Holley/Hooker headers and the exhaust will hit the x member. You will need a custom exhaust shop to help with this.
    Tags for this Thread
