    Results 1 to 7 of 7
      Michigan
      How the caliper is positioned has no impact on whether the car will "pull." The brake rotor has no way of knowing whether the caliper is squeezing it from behind the axle or in front of it; the forces and timing will be identical.
      In order for the car to pull to one direction, there'd have to be in difference in torque between the left and right tires. This could be caused by a frozen caliper piston, blocked brake hose, mismatched brake pads, etc, but how the caliper is clocked on the rotor has no impact.
      Just make sure both your bleeders are on the top so you can get all the air out of the system.
      - Ryan
