    Results 1 to 8 of 8
      Jul 2017
      Ridetech Control Arm Question
      From what I understand, ridetech recommends +5 degrees caster for street driven vehicles.
      My question is: Is it possible to get more than +5 degrees from the ridetech StrongArms?
      *StrongArms for 1970 Buick Skylark
      thank you !
      IL/TN
      get it aligned and see, every car is different, between the upper A-arm mounts and lowers that are separate welded components of the frame no one can tell.
      Mar 2014
      Mesa, AZ
      If you have the newer style arms with the caster slugs you can probably get more than 5 out of it by doing max caster plugs and adding shims. But as stated above you need to get it aligned to see what you've got to work with. Every car is different, and likely you won't be able to get the same max number on each side. On my Chevelle the passenger side was able to get a lot more caster than the driver, so we aligned it accordingly.
      Nelson
      5 to 6 deg is plenty for a street car IMO
      1971 Camaro
      Sep 2018
      Knoxville, TN
      You could either get SPC arms with the adjustable length or order some custom made ones from Coleman (they are pretty inexpensive, about $60) to gain more caster.
      IL/TN
      Quote Originally Posted by 67King View Post
      some may argue but SPCs are a PITA and not worth the money, one adjuster always loosens and one of the bushings on each arm twists and wears out faster.
      Have you checked to see what Colman will charge to make custom arms? not $60 and the ones off the shelf are not a direct fit.
      Sep 2018
      Knoxville, TN
      Quote Originally Posted by 79T/Aman View Post
      Sorry, you are right, the custom offset ones are an extra $20. And I have not done this, but I have seen it. Assuming he is running a tall spindle, they'll work, the will just rest against the frame (like the SPC's) when the car is jacked up since they are flat.
      Feb 2013
      Quote Originally Posted by Yanchik View Post
      thank you !
      On a street car, we recommend that you shoot for 3° to 5°.
      Depending on the car (some frames just won't allow it), it is possible to get more than the 5°. We have more aggressive caster slugs but typically use those in more performance oriented setups.
      Thanks,
      Josh
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
