      Jul 2017
      First Gen Camaro subframe welding
      I need to make a patch on my subframe on my 68 Camaro. I removed the motor and found gouges in the subframe from someone possibly dropping the motor on it or prying the motor up with a sharp object. See photo attacked. Either way i need to cut out the damaged area and weld a new section in. What thickness plate should i purchase to do this repair. I’ll also be notching the subframe a little for my new accessories and i want to use the same plate to do so.Name:  IMG_2317.jpg
      Mountain Springs, Texas
      I would use 1/8”. You can buy small pieces on eBay if you can’t find it local.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Jul 2017
      Found some local and it worked out. Thanks!
