      california
      wich one is high pressure
      wich power steering line hole is high pressure upper left one or lower right one? thanks
      Aug 2003
      Prescott Valley, AZ
      it is the hose that has the hydraulic crimp on fitting. if you have the resivor type pump, it should be the hole towards the driver's side. the gear box, the lower one.
      It's shake and bake!!! and i helped!
      Drewco Homes
      california
      lol
      i know wich hose is high pressure i was wondering wich hole is the high pressure one.. one hole sits low one sits high . wich one is high pressure low hole or high one . thanks
      Mar 2000
      San Diego, CA
      On mine, which I hooked up a few weeks ago, the one near the engine was the high pressure and the one near the wheelwell was the low pressure. On my AGR box, the high pressure one had a slightly bigger fitting so you could not mix them up. Hope that helps.
      Mike Schwartz aka chevymike
      1955 Chevy 210 Wagon
      1965 Chevy C10 Panel Truck
      1972 Chevy El Camino
