      Sep 2009
      Auckland New Zealand
      65 SS Impala Convertible Build
      Hi I'm based in Auckland New Zealand and as the title says I have a 65 Impala that is the final stages an LS Conversion. I was lucky to have purchased a straight and rust free 65 Convertible, It was a genuine SS Big Block Vehicle with Aircon. My brief to Mike Barry from NXT Level Automotive was to the untrained eye the vehicle is to look stock, air ride suspension and wicked stance, the engine bay to be detailed and uncluttered.
      I researched online and thru various forums imported all the goodies and delivered all the parts and the Vehicle to Mike, to say Im delighted with the result is an understatement.
      The vehicle has had the following:
      air ride suspension from Ride Tech
      LS3 Engine Holley Sniper Intake and Cam and Injectors
      Willwood Discs all around
      Hydrotec Brakes with Wilwood Master
      New LSD Diff
      New Fuel Tank and intake fuelpump
      Eddie Motorsports serpentine pulley system
      Eddie Motorsports hinges
      Dakota Digital dash
      A Clean Vehicle to start with
      I suppose what you would call the before pic
      Parts arriving for conversion
      Motor and exhaust installed and test fitted prior to pull down
      Rather than bashing the transmission tunnel it was cut and a modified tunnel fabricated
      Engine painted Bright Red . Running hidden coil packs so using SBC Valve Covers and adopters so new oil fill had to be made
      Strip down getting ready to remove of chassis and clean up fire wall
      Chassis Powder coated
      Firewall Cleaned up
      Motor meets chassis
      Hard lines plumbed
      Body Meets Chassis
      Looking more like a finished product, Happy with the new stance
      Air Intake fabricated
      Because I was using SBC Valve covers with the pre drilled oil filler and breather holes fender emblems were milled to fit
      Air Intake and radiator fill panel colour coded to match car. Coils hidden below The vehicle is in the final stages computer being installed under passenger seat so the engine remains clean and uncluttered
      a bit of before and after
      Jun 2016
      Wow! Great job on the build. It looks so clean.
      What size headers did you use. Have a part number. Turned out amazing
