    Results 1 to 10 of 10
    Thread: Too much vacuum
      Feb 2012
      Too much vacuum
      I am stumped my dads new crate motor 351 is producing over 200” of vacuum and you can actually hear a whistling after you shut it off. I removed the pvc valve no change checked for restrictions in the carburetor and choke etc removed the cleaner also no change. It’s effecting they brake booster.
      Any ideas?
      Beach Park IL
      Two Hundred (!) inches of vacuum? At that number you don't have a crate engine, you have a black hole.
      If you actually meant 20", that is not too high and is not the cause of your whistle.
      Donny
      Feb 2012
      It pegs this gauge to the end of the red. Like I said very strange and you can hear the engine still sucking “ equalizing” pressure for about 2 seconds after you shut it off!
      Beach Park IL
      I bet it does. There are 25.4 mm in 1 inch.
      What is the brake booster doing?
      Donny
      Feb 2012
      Just noticed the gauge is mm of vacuum “head slap”
      Beach Park IL
      Is the check valve in the booster any good? That would allow vacuum back into the intake after shutting off the engine.
      Donny
      Feb 2012
      Pedal goes down after pressing it a few times and then starting engine. Pedal feels good at first then goes hard. Going to replace the fuel line hose with brake booster hose and check the check valve. IfInhit my head on this 41 Ford hood anymore today I might loose it!!!
      Sep 2008
      Jacksonville, Florida
      Definitely going to be my favorite quote this week.
      Craig Scholl
      CJD Automotive, LLC
      904-400-1802
      www.cjdautomotive.com
      "I own a Mopar, I already know it won't be in stock, won't ship tomorrow, and won't fit without modification."
      Oct 2014
      DFW, Texas
      Quote Originally Posted by hiflyr View Post
      d'oh
      1972 Plymouth 'Cuda - Not LS-swapped, 5.7L Hemi [MS3 Gold Box], T56 Magnum 6-speed - 'Cuda Build Page
      1976 Dodge D100 - Warlock
      2016 Subaru WRX - E30 Tune
      Central CA USA
      My daughter had a 302 Bronco. Could hear vacuum bleed down after shutting off. It had that bent over EFI intake. I think it has a lot of plenum capacity to store vacuum.
