    Results 1 to 11 of 11
    Thread: what's going on
      what's going on
      Hi all, I decided to go with a fuel injection unit for my firebird but I ran into a problem. The engine is your typical sbc out of an 88 vette so why is it that the holley stealth ram pn#91505201 doesn't sit right? I called them up & they said to use felpro gasket #1206 which are .060 thick but I still seem to have a gap. Now, I forgot my micrometer at work so I really can't give you guys any numbers. but as you can see from the pics. there is a raised area on the heads. Does anybody know why this is here & more importantly how do I resolve this issue without removing the heads having them milled. I thought the heads were your run of the mill 58 cc chambers now I'm worried. What are they?
      Aug 2001
      Wilton, CA. (Sacramento)
      My Hogans sheetmetal manifold was the same way on LT1 heads. I had to machine the intake to clear. Pretty simple but I didn't expect it.
      Jody
      Won't that make the area around the injector very thin?
      Aug 2001
      Quote Originally Posted by mlr1026
      very possible, that manifold may not work on those heads. On my Hogan manifold it was fine but they locate the injectors in a different spot.
      I just went out to my shop and looked at the stealth ram I have out there; it does not have that injector boss out like that, it is flat across the top of the port. I wonder if that's an older designed manifold or why it is that way.
      Jody
      Vancouver, Washington
      I have an '87 Vette, so I went out in the garage to look. The heads have the same ridge on them. I couldn't tell you why they machined it that way, but I see how it causes problems.
      Ron
      '70 Nova SS, ZZ383, DSE coilover conversion, minitub, Quadra-Link, Baer brakes and more to come.
      '05 CTS-V, Stock at this time (the Nova is taking too long)
      2004 Kosmic ICC 125 shifter kart (enough g's to bruise your ribs!)
      2002 Tony Kart ICC 125 shifter kart (dito!)
      Another thought. There are two stealth rams; one for old style heads and one for Vortec heads. The ports are different.
      Ron
      Mar 2003
      Kirkland, WA
      Do your heads have vertical intake manifold bolt holes? I think GM chnaged how the intake mounted to the heads around '88.
      James
      -1969 Camaro Sport Coupe
      -1996 Z28
      -2005 Silverado
      Webpage
      Check with Andrewb70. He works at Holley and can help you with it.
      Ron
      Quote Originally Posted by Nova-Mann
      I actually no longer work for Holley, but I will do what I can to help.
      Mario, I sent you a PM, but now that I am reading this post I am know what the problem is. The manifold that you have there must be fairly old. I can tell by the tooling points. Like Jody said, not all manifolds work on all heads without modifications. It is actually fairly common that the manifold will need to be trimmed in exactly the area that your showing in the pictures. If you are comfortable you can trim the area yourself by hand. If not, then you can have a local machine shop mill the area. Make sure that you take off as little as you have to. I would also use a 1205 FelPro gasket. The 1206 is HUGE and there is no reason to use it with the heads that you are using.
      Thanks For The Advise Guys
      Ontario, Canada
      The aluminum heads I used on my 400 sb appear to be the same as yours. I'm using an older Wiend Xcellerator single plane on it. When I went to drop it on, I experienced the same problem. I spent a half hour or so trimming the sides of the manifold down with a file. I think you should be able to do the same without causing any problems with your injector bosses.
      Ken
      My other car is a Vega.
