    Results 1 to 11 of 11
      Jun 2017
      Billet filler and cap
      Looking to add a billet fuel filler and cap to my 1972 Dodge Dart. The only one I’ve found is with classic industries, and it’s a universal fit - “some fab make be required.”
      I got this piece, and while nice, not even close to fitting, so much so that it’s also not worth the fab work necessary to make it work.
      Does anyone know of another source, or mfg, or place where they have these available for older cars?? Any help is appreciated.
      Thanks in advance....
      May 2013
      Colton Ca.
      Aug 2015
      charlotte
      Jun 2017
      Quote Originally Posted by Build-It-Break-It View Post
      ahmad, thanks for responding. I should have mention Ned that while I got this piece from classic industries, it is in fact from Ridetech.
      Jun 2017
      Quote Originally Posted by slimjim View Post
      Thanks for responding. I like the design but unfortunately it won’t fit for the same reason. I need a max inner diva of 2.25, so the 2”here works, but unfortunately I need a max dia on the outer cap of 3.5, and thE small version is 3.75. This would require more fab than I’m willing to do on the outer skin tto make it work.
      Thanks though!
      Aug 2015
      charlotte
      you may have some luck looking into road bike gas caps then, the variety Is huge but it's often hard to get dimensions.
      Jun 2017
      Someone has suggested that, and while it's a solid idea, the fab work necessary to make it work makes me think that i can just do the same fab work for the ridetech cover. Was hoping that someone out there made one already that fits, but I may have to do the fab no matter what.
      Thanks!
      Jonesboro, Arkansas
      Tanks Inc has one also look here... http://www.tanksinc.com/index.cfm/pa...rod/prd566.htm Not bad priced either..
      Carl Wilson
      Aug 2015
      NJ
      I have one like the OP posted up on my '68 Camaro and can say that not only does it look good, it functions even better. The original filler neck for my car always caused spillage. This one is perfect and the pump kicks off automatically without such as a drop of gas shooting out.
      '68 Chevy Camaro Pro-tour ~ project DMENTD
      '57 Chevy 3100 Pro-tour pickup ~ under construction
      Jun 2017
      Frankly - I wish I could use the ridetech cap as it really looks like a nice piece. Problem is the "hole" in the qtr that the cap needs to fit into is only 3.5" OD, so either the cap needs to get smaller, or the cap will fit far outside the surface of the qtr. I have a buddy with some CNCs and talking to him about trying to make a custom filler that the ridetech cap will work with. Not seeing anything other than stock which will work with little/no fab,
      Aug 2015
      NJ
      Quote Originally Posted by Velocity111 View Post
      The problem is the cap and neck fit together as one piece. If your car needs body work, cut it out and fit it in bro. Would not be hard to make that mod if you can cut, grind and weld. Since it is on the quarter, i'd paint it to match - just my 2 cents
