    Results 1 to 20 of 26
      Mar 2018
      QA1 shock broke on first day back!
      So on the day I pick up my car (after being gone for two months for suspension, brake, wheel/tire and rear end upgrades) I see a leak coming from the driver's side rear wheel. The shock cracked! I haven't even driven it two miles when I test drove it when I picked it up.
      Now I gotta trailer it on a two hour trip back to the shop to get it replaced.
      What a kick in the nuts
      Has anybody else has issues with qa1? OR IS THIS AN INSTALLATION ISSUE?
      Beach Park IL
      It is hard to tell, but it looks like the shock body is hitting the bracket at the bottom. Based on where the crack is, it seems that is the problem.
      Donny
      Metamora, Illinois
      ^^^What he said. I don't know what was included in the rear suspension work you had done, but whoever installed the rear shocks should have cycled the rear suspension through it's full range of motion, compressed/extended to check for issues like this.
      Jul 2015
      x3 looks like the spring adjuster nuts are hitting the shock mount.
      Feb 2013
      Saskatchewan, Canada
      Looks like, when pinion angle was being set, the diff is rotated to far up causing shock and bracket contact, just my opinion.
      Mar 2018
      update: they're going to change the location of the shock bracket. he didn't like the angle that the kit had the rear shock mounted. And yes...he should've spotted it the first time
      IL/TN
      YUP the shock body is against it's mount acting like a giant pry bar, who built that?
      https://www.protouringf-body.com "doing what they say can't be done"
      Mar 2018
      The mount and shock were both Qa1 parts. The mounts were both refabricated and are working well at the moment. See pic
      IL/TN
      Quote Originally Posted by dkar26 View Post
      I'm not understanding what you are saying! we know the shocks are QA1, you say the mounts are QA1, then you say the mounts are fabricated ??
      picture on the left has clearance to the shock body, picture on the right does NOT have clearance and the pic on the right has the bracket that broke the shock.
      Mar 2018
      Sorry. “Fabricated” meant it was cut (as you see in pic) to allow better clearance
      IL/TN
      so you trimmed the original bracket to give clearance to the shock body and it's all good now.
      Metamora, Illinois
      You have a little bit of clearance, but that looks more like a band aid fix. I guess you will have to see how much travel/movement there is with the suspension to see if it makes contact. Are they sure they didn't weld the brackets on wrong and/or the pinion angle is off?
      Mar 2018
      Quote Originally Posted by rocketrod View Post
      Who knows? Hopefully not.
      So far so good at this point.
      I wish there was a good hot rod shop nearer to me.
      corona,ca.
      Quote Originally Posted by 79T/Aman View Post
      In post
      #8 he said 'refabricated '
      Op, when I made my rear coil over brackets,I had the frame on jack stands, removed the springs and mounted the shocks,and cycled the suspension from ride height,to compression,then to
      Ext,also rotated the axle extreme left and right fyi.
      Everything cleared.
      72 chevelle.
      corona,ca.
      What state are you in,and what car is this?
      72 chevelle.
      corona,ca.
      What state are you in?
      72 chevelle.
      Aug 2010
      now In Dandridge, Tn.
      Glad it is fixed. BUT, information is king. It would help the rest of the P.T. community if more info was given. What mount kit, and from where, What shop did the install, (not knocking them, they trusted the parts to be correct, and fixed the problem, Also, I hope that there was no cost to you) Actually, this proves that the shop has some level of integrity and stands behind there work. What kind of car is this? and, where are you located? I do not encourage any 'bashing' but this info could help you, and others to avoid the same issue.
      Mar 2018
      Northwest Indiana just south of Chicago.
      Mar 2018
      it was a QA1 Stage 3 kit for a 70 Chevelle. From what i understood from speaking to the QA1 sales rep, the kits are not as "bolt-on" for Ford 9" rear ends, which is what I had
      To their credit, the shop did do the necessary repairs without any added cost to me (other than I had to drive another two hours round trip)
      Mar 2018
      They are called Studio Hot Rods in Richmond, IL. They have a ton of five star reviews.
      They've gotten a lot busier in the recent past and i'm thinking some of their Quality control has fallen off a bit because of their busy-ness.
