    Results 1 to 11 of 11
    Thread: Heat shrink
      Jun 2009
      From Wasilla, AK. Now portland, OR
      Heat shrink
      So i have some wiring i am cleaning up and eliminating some connectors in my holley efi harness. does anyone have a recommendation for heat shrink ? it will be in the heat of the engine bay. thanks.
      1970 Elcamino ls3/t56, ricks/vaporworx, sc&c afx ,forgeline zx3, kore3 z51/ls1
      1969 Camaro ls3/t56, ricks/vaporworx, ride-tech,forgeline ga3,
      2024 ford maverick
      Feb 2013
      South Carolina
      I'd look for a marine grade heat shrink. It has an inner coating of adhesive to seal the wire ends.
      Mountain Springs, Texas
      I use double wall self sealing that shrinks 3x if I remember right. I get it on eBay.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Michigan
      I agree with the above posts. I get mine from Amazon. $10-$20 for a box of assorted sizes (depending on diameter, whether you want adhesive lined, which I recommend, and shrink ratio).
      - Ryan
      Oct 2011
      Cincinnati Ohio
      Harbor freight has a nice assortment of the marine shrink tubing for about 8-9 bucks. I usually keep 2 to 3 sets so I never run out.
      1/4” is what I use most of the time:
      https://www.ebay.com/itm/50-6-Pcs-1-...72.m2749.l2649
      Don
      Jun 2015
      Mississippi
      mil spec, they have a ebay store that sells smaller quantities
      https://prowireusa.com/c-27-raychem-dr-25-.aspx
      some of the marine stuff ends up being stiff
      May 2019
      Pensacola,Fl.
      Quote Originally Posted by JustJohn View Post
      What he said...
      Raychem DR25 is the stuff to use in the engine bay. You can get it at prowireusa (see Strip's post above), McMaster-Carr, Fischer Motorsports, etc.
      ​John Parsons
      Feb 2019
      Kankakee IL
      Amazon has dealers that sell it in 100' rolls.
      Tracey
      May 2019
      Pensacola,Fl.
      Quote Originally Posted by Kcrain View Post
      Yea..It's heat shrink..But it is NOT the good stuff. The good stuff as said is the marine grade w/glue in it.
      https://www.amazon.com/Ancor-Marine-.../dp/B000QCPKE8
      Please use RED heat shrink on your Positive terminals.
