      Jun 2008
      tremec guide pin backing out
      I have a tremec tko600 with a hydraulic GM clutch in a 68 Camaro (behind a LS3 with hot cam). noisr started in clutch like a throw out bearing but build only has 3500 miles. Put light pressure on clutch pedal, noise stops, anytime clutch fully out no noise. Pulled inspection plate and the guide pin for the hydraulic throw out bearing has backed out and it touching the fingers of the pressure plate. Has anybody else had this? I think its threaded in there, so I can assume it can come out all the way? I didn't build the car, I had a builder do it for me. So I am not exactly familiar with the set up.
      thanks
      Brad
      Jun 2008
      Upon further review... It looks like its the pin that holds the hydualic lines in place? Is there such a thing? Is it threaded or knocked in?
      Feb 2016
      Lawrenceville, IL
      Is there any way for you to post some pictures? I will do my best to try and help you out.
      visit us on the web at www.bowlertransmissions.com
