      Austin,Tx,
      Help with clutch issues
      I'm trying to figure out why i can't push the clutch pedal in. I went out to get parts while a buddy of mine assembled the clutch and put it on the motor. My question is, if he put the clutch plate in backwards would it cause this? I'm using a centerforce clutch in a 4 speed muncie. Any help is greatly appreciated as i am about to pull this motor back out. Thanks
      Paul
      1969 RS Camaro
      1985 Buick GN
      2005 F-250
      Central CA USA
      The pedal won't move at all???
      Maybe he got the fork in the TO bearing wrong.
      Check to see if the fork is hitting the firewall where the pushrod connects. That happens on Camaros when the wrong height TO bearing is used.
