    Results 1 to 12 of 12
      Oct 2008
      Seattle, Wa
      4th Gen Camaro Radiator Install - 69 Camaro
      Hi guys,
      I know several people have installed 4th gen LS1 (or LT1) style radiators in their 67-69 Camaros. My question is how are you mounting them?
      It seems easy enough to make L brackets to support the bottom of the radiator, but I'm not sure how to secure the top. One thing I thought of was cutting out the core support to accept the tabs/clips on the radiator.
      If anyone has any pictures of their install, that would help a lot!
      Thanks in advanced!
      -Ryan
      1969 Camaro - LS7/T56 - Art Morrison Front Suspension/Ridetech Coilovers
      Instagram: @rbreezee88
      Mar 2013
      Napier, New Zealand
      Country Flag: New Zealand
      G8 Radiator
      I used a G8 radiator and fans, it has brackets at top and I used rubber mounted bolts
      Damien
      Napier, New Zealand
      Project Page: https://www.pro-touring.com/showthread.php?99096-Project-Camaro-68-P-T-Muscle
      Next Project: 1956 Chevy Truck, Full C3 Suspension, Nascar Inspired
      Oct 2008
      Seattle, Wa
      That’s a really nice setup! I’m assuming you fabricated your own brackets to mount to the core support?
      Mar 2013
      Napier, New Zealand
      Hey, cheers, I put a bit of work into it.
      Yeah, they are pretty simple sheet metal pieces. If you don't have OTR, you could use top of rad support and bolt threw.
      You cant beat GM factory parts, easy to replace and designed to work in a dessert. Cant go wrong, way better value than any aftermarket gear.
      I bought new radiator and got the GM fans from a wrecker off a low mileage car. Good for 100K miles easy.
      And I just used the G8 radiator hoses, couldn't get any easier, all keep on shelf at any good parts store.
      Damien
      Napier, New Zealand
      Feb 2009
      muggy midwest
      That is a very sanitary cooling system install!
      "...if at first you don't succeed, try again.
      If you still don't succeed, then quit-no sense being a damn fool about it..."
      -W.C. Fields
      HARNESSWORX
      (formerly gmachinz)
      Oswego il
      Quote Originally Posted by Tweak View Post
      Very clean, tell us more about the air box/intake. Is that something you made, or for sale?
      Oct 2015
      Western Mass
      Just curious... would the 4th Gen Radiator work with a non-Ls power plant? Would it work with a SBC or BBC?
      '69 LeMans Blue Coupe, White Interior, Massaged .030" over 454, Super T10 4-Speed,
      Holley 4150, Pertronix Ignition, CompCams Xtreme Energy XS274S, 781 Oval Port Heads
      Oct 2015
      Western Mass
      Very Impressive, beautiful work. Was there a technical or aesthetic reason you moved the radiator back off the core support?
      Mountain Springs, Texas
      Quote Originally Posted by OldTimer View Post
      It allows the cold air intake to draw air from in front of the top of the radiator. Quite clever.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Mar 2013
      Napier, New Zealand
      Don
      A happy accident was it keeps a very consistent temp, I think its because the whole radiator is exposed to cool air, rather than being up against the core support that blocks the outside edges of the core.
      Damien
      Napier, New Zealand
      Nov 2009
      Peoria, Az
      You wouldn't happen to have a brand for that radiator/fan setup would you? I see them ranging from $150 to $400+ for just a radiator. Which one did you go with?
      Mar 2013
      Napier, New Zealand
      Quote Originally Posted by djorgensen3 View Post
      G8 radiator and fans from a wreck.
      Damien
      Napier, New Zealand
