Thread: saginaw info?
saginaw info?
I tore up my old saginaw 4 speed and just swapped another one in for now. I opened the old one up and the teeth are gone on the input shaft and on the corresponding gear on the countershaft, also the input shaft bearing was split and the front snout was broke. I wanted to run the car on a dyno just for fun but I dont want to tear up my trans again until I get the 4l80e ready to go in so I wanted some oppinions on the trans, whats the chance of breaking somthing if I run it in fourth gear? In first and second the tires break loose so easy that I think I am kinda safe, in third gear boost comes up at about 65 mph and alot of the time it will break them loose again but going that fast if they dont break loose there is a lot of torque being applied through the input and the countershaft. In fourth where the input and output are just locked together, how stout is the connection? Do I dare run it at full power on a dyno where there wont be any real shock on the trans such as dropping the clutch ect?
MikeTurbos, 1700.00
Hot Side, 1500.00
Cold Side, 1,000.00
Fuel System, 1,000.00
The look on the face of whomever the passenger is when the tires break loose at o say 70 mph or so........priceless
