    Results 1 to 12 of 12
      Nov 2010
      Wilwood 7/8" Master Problems
      I just finished installing my Wilwood 7/8" master and can't get a pedal. This master was brand new, and I sent it back to Wilwood for the recall. I finally get around to installing it in my 63 Hemi Dart to replace the 15/16" that was in there. I've bled it twice, and there is definitely no air in it. I can pump it till the cows come home and still no pedal, I'm guessing it's no good. Anyone else having issues?
      Oct 2014
      DFW, Texas
      Did you bench bleed it?
      1972 Plymouth 'Cuda - Not LS-swapped, 5.7L Hemi [MS3 Gold Box], T56 Magnum 6-speed - 'Cuda Build Page
      1976 Dodge D100 - Warlock
      2016 Subaru WRX - E30 Tune
      Mountain Springs, Texas
      I would plug the ports and see if it builds pressure. That is the method I use to bench bleed.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Feb 2011
      dallas, tx
      vaccuum bleed it from the reservior. After trying to bleed my buddies for 30 min and ZERO pedal i put a vaccuum pump on it, shoved a line into the reservoir and pumped away. After 5 min we had a solid pedal. see link below. Worked like a charm
      https://www.youtube.com/watch?v=1jhGAceCpx4
      Nov 2010
      Quote Originally Posted by GoodysGotaCuda View Post
      Yes,
      Nov 2010
      Well I just got off the phone with Wilwood, as it turns out the 7/8" master is too small for my setup, they recommend a 15/16" master ( what I took out ). Looks like I'll have a Master for sale....
      Oct 2014
      DFW, Texas
      7/8" is a little small for me, but it works/bleeds fine. Not sure that another 1/16" is going to resolve any bleeding problems..
      Oct 2014
      DFW, Texas
      Quote Originally Posted by icemanrd19 View Post
      I've seen quite a bit when it comes to cars, but this one was new to me. I went ahead and tried this on what I thought was a well-bleed system. I am pretty certain the air wasn't induced by my process and I was able to pull a ton of air out of the master cylinder.
      The pedal feels slightly better, I'll know for sure when I go drive it next, I'm excited to see if things got better. They were pretty good before.
      Nov 2010
      Interesting, I might have to try that...
      Mar 2018
      I just tried this with my mightyvac and I couldn't believe the amount of air bubbles that came out! I also just installed a 7/8" wilwood master on my '69 cutlass, but in the process of chasing down leaks, air got into the system. Bled it a few times the regular way but still had a spongy pedal. Came back from a test run and it brakes leaps and bounds better than before with less effort and nice firm pedal. Thank you!!!
      Oct 2014
      DFW, Texas
      Quote Originally Posted by BondAR View Post
      I did notice that on my rear Wilwood port, if I pulled too hard of a vacuum, I'd suck past the m/c piston seal. I knew that because the dust boot that connects that seal area to the brake pushrod would collapse. So I believe I was pulling some of that air through the m/c while doing it. That said, it's probably best to pull a fairly light vacuum on the aft port of the m/c.
      Sep 2017
      check pedal to piston -actuato-radjustment??
