      Mar 2013
      Rear disc for 12 bolt
      Need some budget stock rear disc brakes for my 69 camaro so I can do some track days this year. Will probably upgrade to wilwood or something like that later. Work is kinda slow so I figured stock would do for now.
      Thanks Shane
      Sep 2017
      Livermore, CA
      I went with 4th Gen Camaro/C5 brakes on my Chevelle. So far the performance is great, and you can find most parts at Pick/n/Pull or a junkyard for cheap. I got my whole rear set up on a half off day for $99.
      Mar 2014
      Mesa, AZ
      +1 on the 4th gen brakes. You can get them cheap, throw a rebuild kit and some new pads/rotors and you have great brakes. They work awesome on our Chevelle. Kore3 has the lines to make the install even easier.
      Nelson
      Just remember that for 68-69 Camaro's you will need to run two left side brake assemblies to go around the staggered rear shocks.
      Aug 2010
      Seattle area
      Remember that 1969 Camaros had an JL8 option from the Corvette of that time
      May 2010
      kitchener,Ontario,Canada
      77-81 Seville with the rear disc option , use brackets and calipers . For rotors use 79-81 firebird ws6 rear rotors
      Ryan Austin
      On Instagram ryanaustinss70
