    Results 1 to 2 of 2
      Mar 2010
      Rochester NY
      steering help please
      Hello all - working on some upgrades to the camaro and need some help with getting the right parts/adjustments
      looking to find which steering gear would be best suited for the car and if there is anything else i need to swap out while doing the work
      The car has global west uppers and lowers with coil over shocks
      C5 spindals
      replacing old sway bar with a speedtech unit
      also replacing the steering box with a speedtech 12.7 to 1 because the old is leaking
      Grace - 67 Camaro daily driver with upgrades along the way.
      https://www.pro-touring.com/showthre...-Camaro-Driver
      Dude... I'm telling you... put in a borgeson steering shaft if you can. I just did it on my 71 and it's night and day different. I already had a AGR 12:1 box.
      https://www.pro-touring.com/threads/...aft?highlight=
      1971 Camaro
