      Sep 2017
      QA1 Suspension & Spindles
      Anyone out there use QA1 model HK03-GMA2 Suspension. I'm looking for spindle and hub assembly. I would like to drop the car a couple inches. Just want to make I'm on the right track. I will be using 18" wheels up front with Wilwoods 14" brake kit.
      Thanks in advance
      perry
      Lawrenceburg, TN
      I have a few options that have much better shocks then the QA1, the QA1 is a old design 15+ years, the shock technology has jumped leaps and bounds in the last 5-8 years.... here is a link
      Suspension Geek A-Body gear
      Sep 2017
      Thanks Rod. Found some good stuff. My biggest priority is finding spindles that will fit my QA1 Suspension, 18" wheels, 14" Wilwood brakes and Flaming River power steering. I did find through Suspension geek that ridetech has a set of 2" drop spindles I would like but it appears that I would need to buy some stock steering arms and one thing I don't know is if the brakes calipers bolt directly to the spindle or is there is a bracket I need.
      Here's the spindles I'm looking at
      https://suspensiongeek.com/products/...-spindles-pair
      I'm encouraging anyone one out there to share their knowledge as Rod has. Let me know what kind of spindles you have
      Thanks for your time
      Perry
      Lawrenceburg, TN
      those spindles will take any A-F-X body brakes, the willwoods you have should have a bracket that mount to the spindle.....what steering arms do you have?
      Apr 2017
      Lakeville, MN
      Zombie666: I just came across your thread here. Our kit will work with any spindle that works with your factory control arms. The upper arms are designed to give better negative camber gain, so a taller spindle is not necessary. We have extended length ball joint studs for the ball joints that are in your QA1 control arms if you need/want to play around with different control arm geometry.
      Hope that helps. Let me know if you have any questions.
      Bill Foley
      Technical Sales and Support
      [email protected]
      952-985-6371
