    Results 1 to 17 of 17
      Raleigh, NC
      Intercooler for 1st Gen Camaro ('68) ... Questions...
      Hi Guys,
      I'll be adding an intercooler to my setup and want to be sure that I'll be able to mount the FMIC without blocking any hood latch parts, etc...
      What's the choice of 1st Gen owners???
      I'm looking to use either a 3 or 4 inch thick core...
      Any success stories?
      TIM
      '68 Camaro SS 383+D1SC, Orion Silver (Dyno #'s Soon!)
      '95 Camaro Z28 383 LT1 (405 RWHP/428 RWTQ, SAE - DynoJet)
      '99 Corvette LS1
      Albuquerque, New Mexico
      One of my buddies is building a twin turbo ls1 setup in his '68.. won't be done for a while, but I'll see if I can jack their ideas for ya.
      Aug 2001
      Wilton, CA. (Sacramento)
      Here's one from Ron Davis Radiators specifically for the first gens. Uses the stock hood latch. Doesn't block the whole radiator, and allows the Vintage Air condenser to be used also.
      Jody
      Burnaby, BC, Canada
      Check out Jody's old project: http://www.camcojb.com/twinturbo/
      There are some ideas and lots of pics of his custom intercooler setup. I'm sure he can help you out.
      EDIT: I guess we posted at the same time, sorry.
      1969 CAMARO RS
      Project pics of my '69
      Lateral-G Feature Page
      Jan 2000
      Thousand Oaks California
      Here is the one I had Ron Davis make for my '68. It does block the latch but that's the way I planned it. I plan on running a pair of Corvette latches in the corners to eliminate that problem. It's massive and it's my design. After seeing Jody's I kinda kicked myself in the head but, I'm sure it will far exceed my needs and I love it.
      Funny thing is here are my first sketches before I decided to eliminate the latch.
      Larry Callahan
      Apr 2003
      Central Valley, CA
      Larry, can you post pics of your 'Vette latch setup?
      I still need to fit an intercooler on my car and the hood latch and bracing for it is a HUGE obstacle in my fitment... I didn't really want to go to hood pins/locks sticking out of the hood and I'd like to see your 'Vette latch solution. What year latches are you using?
      Troy
      1969 Chevelle
      Raleigh, NC
      Thanks Guys...
      I'll give Ron Davis Rads a call...
      -TIM
      '99 Corvette LS1
      Feb 2002
      Springfield, MO
      Here is mine, Griffin core with tanks made by a buddy.
      Jimmy
      69 Camaro Twin Turbo'd
      58 Nomad 348 Baby Rat
      Jan 2000
      Quote Originally Posted by Blown353
      Troy
      Troy, I've not had time to install it yet but here are the parts and where I will put them. I'll make sure of the year but I think they are '85's
      The pictures are not very good but it gives you an idea.
      Larry Callahan
      Jan 2000
      Quote Originally Posted by Larry Callahan
      I totally forgot about this. Not only was my first thought like Jody's I even made one out of foam board.
      Check these out. LOL!
      Larry Callahan
      Sep 2002
      So. Cal
      I guess I started off the Ron Davis intercooler craze. I can't say enough about the Ron Davis products. With the custom work it was still a cheaper way to go with I think Better quality. I was able to fit behind the core support due to the engine setting back 4", but I like the shorty in front. I'm curious to see the eff. differences vs. pressure drop comparision. Currently mine runs around 100-115 at the intake manifold at 10#of boost at 60-70 outside air temp. Not bad, If I remember right thats about a 150 deg drop. I still need to get a pressure drop.
      Ron Davis Intercooler
      Ron Davis Intercooler/Radiator
      Ron DeRaad
      68 Camaro RSx
      Darton Sleeved LS9 - 434ci (4.155x4.00)
      AFR LSX245 Heads (12:1cr)
      660hp/588tq
      Sep 2002
      So. Cal
      Actually my bad....I got it from Larry....He started it.
      Ron DeRaad
      68 Camaro RSx
      660hp/588tq
      Socal, Ca
      Wow! Larry and Ron have beautiful rides. I can't wait to see the final product.
      Sep 2002
      So. Cal
      I know I'm way behind on picture updates. You can see some in the Update section.
      Ron DeRaad
      68 Camaro RSx
      660hp/588tq
      Celina, Texas
      I'm also in contact with Ron Davis for mine. Now if I'll just get off my butt and go measure some for it!! I'll post updates here.
      Jan 2000
      Ron! Long time no talk too. For those that don't know we just live maybe 3 miles apart. I so need to come over and visit. I'd love to see the car. Mine still looks like it did when you came over. Talk about slow!
      Larry Callahan
      Sep 2002
      So. Cal
      Its back in the air getting worked on. After some miles I'm going through everything. Mostly minor stuff. I pulled the McLoud twin disc to see why it was engaging so far down on the pedal. My fault...I'll take the blame on that one. Throwout bearing adjustment Good thing it easy with this car. I pulled everything within an hour.
      Anywho, If I can remember where you live I'll drive by one weekend so you can take a drive. I'm going to do my best to finish interior in '06. Nothing another 10-15K wouldn't cure.
      Ron DeRaad
      68 Camaro RSx
      660hp/588tq
