    Page 4 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
    Results 61 to 80 of 175
    1. #61
      Indiana
      Great progress!
      Herb
      1966 Chevelle 509/T56Magnum
      1963 C10 454/4L80
      PHR CHP CHP youtube
    2. #62
      Oct 2015
      Tired of doing body work so I did a little fab work. What are your thoughts? Something a little different, more for show than go.
    3. #63
      Oct 2015
      Got tired of body work and went back to some fab work, making some bbc valve covers fit my ls.
    4. #64
      Oct 2015
      I’m having a hard time finding a place for the coil packs, I ended up mounting them on the firewall, I don’t want to see them so I had to build a cover for them, between the cover and my valve covers I should be able to hide all of my wiring to keep motor looking real clean. My only concern is if emi will be a problem.
    5. #65
      Oct 2015
      Redid exhaust tips and made covers which need cleaned and polished. I started making cold air intake with 5” pipe and covers for engine oil cooler and power steering cooler. Also installed new style hood latch out of a 2018 Silverado and striker out of 2018 traverse.
    6. #66
      Beautiful job! I love it.
    7. #67
      Oct 2015
      Thanks, I really love doing this stuff but I’m starting to get a little impatient because I have been working on this thing since 2015. Probably doesn’t help that every part of the car has been altered.
    8. #68
      Oct 2015
      More updates finally, been doing body work (struggle), finally going to get painted in about a month, finished making close out panels for front, installed new style hood latch , latch out of 2018 Silverado, striker out of 2018 traverse, had to weld bottom to trunk lid to make straight, bought new calipers from z06, painted bottom of car with rapture, I did not like passenger door, did some digging and found some rust that previous guy had covered up when this project was started, had to replace most of bottom of door and installed new door skin, cleaned frame up and sent off to powder coat
    9. #69
      Wow great work, it's looking good. If you want to feel better about how long you' been building this check the date I started mine. LOL Great job.
    10. #70
      Oct 2015
      Great build. That firewall turned out amazing. What color are you going with?
    11. #71
      Oct 2015
      Thanks for the compliment Motown 454, you definitely have been at it a lot longer than me. I have always had something fun to drive but this 5 year break is getting to me . Your car looks very nice, should be a blast to drive!
    12. #72
      Oct 2015
      Alwhite 00 I’m going to paint it the same color as my drag car, I know that’s pretty lame but I love the color. Blue mist poly
    13. #73
      Oct 2015
      Nice color.
    14. #74
      coolest valve cover conversion i have seen yet! going to be a badass car.
      Dig the color!
    15. #75
      Oct 2015
      Impalaman1 thanks for compliment, I think it should look pretty good when done, it hides the injectors and all the wiring. The motor should look real clean when done.
    16. #76
      Oct 2015
      I’m finally getting to put some stuff together for the last time hopefully. Put almost all of the drivetrain together except for trans, waiting on torque converter and have to finish painting trans. I milled the trans pan to get rid of logo and to make it so I can sand ribs after base coat to give it color contrast . All the suspension is UMI stage 5 kit and brakes are Kore 3 ZO6. Motor is my own 416 with Wegner supercharger, cam and drive kit. Trans will be 4l80e with parts from Jakes performance. Torque converter is from Protorque. Rear end is a regular 9 inch with trutrac and 35 spline axles from Moser. The body should be off anytime now to get painted. I ordered wheels from Boze, they said 6-8 weeks. With any luck I should be able to at least take it for a cruise later this fall. (Fingers crossed)
    17. #77
      Aug 2019
      WOW WOW WOW fantastic
    18. #78
      Oct 2015
      Thanks Cobraace2.
    19. #79
      Aug 2009
      Chandler, Az (from west NE)
      Looking great so far. Mine is Mist Blue from the factory. Your's looks like a shade between Mist and Marina blues. I like it, not too light or too dark!
      Ric
      2002 s10, DD and AutoX.
      1966 Malibu owned since 1971. Drag car converting to track toy!
    20. #80
      May 2015
      Very nice build!
      I like the BBC valve covers.
      What are you doing to the trans pan?
