      Vibration Problem Tremec and a BBC, Please help
      It is like oh my gosh where do you start? Due to my inexperience and lack of knowledge I have paid so large tuition bills in the last couple of years. I have 70 Chevelle with a 454 (468 .060 over) engine with a tremec TKO. It has a lakewood bellhousing. I did not check the runout. (First Problem I am learning). The engine was balanced with the flywheel and pressure plate. I am getting a slight vibration from the engine when I rev up the engine with the clutch petal pressed in and when the clutch is not pressed with the transmission in neutral. I also have experienced problems getting the transmission into third, like explained in other parts of this forum. Does this sound like a engine misbalance or a transmission misalignment? Any Help or insight would be appreciated. Thanks
      Ben
      Omaha Nebraksa
