      Dec 2009
      San Diego, CA
      Ridetech Compressor Electrical Connector
      Hi,
      Hopefully ridetech reps chime in. What type of connector is used for the compressor. Upgraded from an E2 to an E3 and finally getting around to wiring the system up. The old E2 used a relay to power the compressor (so no connector) and the new E3 provides a ground (with unrecognizable connector) only for the compressor. I'd like to get the both the female and male housings and pins. Also can, the fuses be substituted with circuit breakers instead? Thanks in advance.
      Robert
      Robert Icasas
      Projects:
      67 Cougar
      Art Morrison Sport IFS
      3-link Rear Suspension
      Coyote w/ D&D Performance Viper t56
      Des Moines, IA
      compressor side. . .
      connector: 0428180212
      terminal: 428171014
      wire harness side. . .
      connector: 0428160212
      terminal: 0428150011
      You can get them at Digi-Key, Mouser, Allied Electric, etc.
      Let me know if you need anything else!
      Dec 2009
      San Diego, CA
      Perfect. Thanks Britt
      Robert Icasas
      Projects:
      67 Cougar
      Dec 2009
      San Diego, CA
      Quote Originally Posted by marolf101x View Post
      terminal: 428171014
      Hi Britt. You wouldn't by chance be able to sell some would you? The terminals are coming up obsolete and/or having to buy a minimum quantity of 100 or 2500.
      Robert Icasas
      Projects:
      67 Cougar
      Des Moines, IA
      Unfortunately we don't typically have many connectors or terminals on hand as we don't build the harnesses in-house. So we may have some in the warranty department for repairs, but I'd have to check how many we have.
      Here's the Molex page:
      http://www.molex.com/molex/products/...e=Introduction
      You can browse the terminals for alternative part numbers. They offer them gold, silver and tin plated, so there are some options.
      Digikey has everything individually:
      https://www.digikey.com/products/en?keywords=0428180212
      terminal: 428171014
      https://www.digikey.com/product-deta...6CT-ND/5423698
      https://www.digikey.com/products/en?keywords=0428160212
      terminal: 0428150114 (silver plated)
      https://www.digikey.com/product-deta...4CT-ND/5423696
      Hope this helps.
      Also, you can use circuit breakers on the compressors if you so choose.
      Dec 2009
      San Diego, CA
      Thanks Britt. That helps. Initially when I looked at Digikey, it was only displaying cut strips.
      Robert Icasas
      Projects:
      67 Cougar
      Des Moines, IA
      No problem. If you need anything else just let me know. Post on here, or send me an email (britt@ridetech.com)
