    Page 3 of 9 FirstFirst 1 2 3 4 5 6 7 8 ... LastLast
    Results 41 to 60 of 176
    Thread: Chevelle 2.0
    1. #41
      Germany
      Country Flag: Germany
      Very nice welding and build ! I need to learn alot for my build, lol.
      The engine with the aluminum block looks good, too.
      You go with the Corvette rims ?
      Sub´d and greetings from Germany.
    2. #42
      Indiana
      Quote Originally Posted by Autobahn-Outlaw View Post
      Thanks! The Corvette wheels were just for test fitting and are now back on the Corvette where they belong.
      Herb
      1966 Chevelle 509/T56Magnum
      1963 C10 454/4L80
      PHR CHP CHP youtube
    3. #43
      Indiana
      Not much too update other than picking up another piece of the puzzle from Bowler Transmissions. Once I get a bellhousing I’ll be able to mock up the engine and trans location.
      T001 by Yelcamino, on Flickr
      T002 by Yelcamino, on Flickr
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
    4. #44
      Indiana
      Just a few small updates...
      On the engine, I got the cam installed, degreed it (ended up 2* retarded), and checked piston to valve clearance (.120" intake, .160" exhaust). I also installed the rocker stands but I'm going to wait until I get closer to starting the engine before I install the rest of the valve train. No sense putting the valve springs under stress while it sits on the stand.
      10101 by Yelcamino, on Flickr
      10104 by Yelcamino, on Flickr
      10105 by Yelcamino, on Flickr
      Next was a big step forward on this project... separating the body from the chassis! Now that this is done, there's no going back!
      10083 by Yelcamino, on Flickr
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
    5. #45
      Indiana
      I finally got the nerve to start cutting on the Chevelle. There isn’t much original left on this car other than the main body, but I was still fretting cutting it up because of this…
      10095 by Yelcamino, on Flickr
      In the end, my inner Roadkill rose to the occasion and I busted out the sawsall and plasma cutter! The first cut is always the hardest, but once that was done, it was a free for all!
      10084 by Yelcamino, on Flickr
      With the trunk cut out, the next step was the first test fit.
      10085 by Yelcamino, on Flickr
      Of course, once it got close to the frame, I saw a bunch of other stuff in the way, so I cut some more.
      10086 by Yelcamino, on Flickr
      After that second round of cuts everything looked good and I started to lower it down until the rockers hit the frame supports (in the red lines, two on each side). Back up it went and off they came.
      10087 by Yelcamino, on Flickr
      And just like that she fits! As I stared at it, the rear looked really low, so I went out the El Camino and took some measurements to compare. Keep in mind, the chassis is level to the frame table so there’s no rake at all. Compared to the El Camino, the front of the Chevelle is about an inch lower, but the rear is 3-1/2 inches lower! Talk about mind blown! I never realized the El Camino had so much rake to it.
      10089 by Yelcamino, on Flickr
      This view is from the front. Next step is to finish cutting out the floor and tunnel so I can put the new floor supports in.
      10090 by Yelcamino, on Flickr
      Engine compartment looks good. I have to remove the heater box and most of the firewall if I want to move the engine back as far as I originally planned.
      10091 by Yelcamino, on Flickr
      The Ron Sutton 3-link looks happy.
      10092 by Yelcamino, on Flickr
      Imagine this view with 315’s tucked in there!
      10093 by Yelcamino, on Flickr
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
    6. #46
      Herb,
      You're living the dream!!! Keep it up.
    7. #47
      Indiana
      Herb,
      I'm trying!
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
    8. #48
      Mapleton, IL.
      Looking good.
    9. #49
      Indiana
      Quote Originally Posted by 64G-lark View Post
      Looking good.
      Thanks!
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
    10. #50
      Indiana
      It’s hard to believe five months has passed since my last post! It’s been a busy summer but I finally found some time to work on the Chevelle. Over the last few days I finished cutting out the floor and firewall.
      10097 by Yelcamino, on Flickr
      10100 by Yelcamino, on Flickr
      Then I added in the two 2x2” rails to connect the front and rear chassis sections. More bracing will be added but this is just to get me started.
      10102 by Yelcamino, on Flickr
      Once all that was done I put it on the ground for the first time in about two years! My curiosity was killing me so I scaled it just to see.
      10103 by Yelcamino, on Flickr
      Notice the driver side is heavier and the front bias is pretty light, but I’m sure the hood sitting on the roof skewed things a bit. Now that I have a baseline, I’m going to weigh it after each major change, such as the cage, engine & trans, etc. My goal is to not exceed 3400 lbs.
      Well here it is…
      And here they are…
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
    11. #51
      Indiana
      Here are some more pics from today...
      10109 by Yelcamino, on Flickr
      10110 by Yelcamino, on Flickr
      10107 by Yelcamino, on Flickr
      10108 by Yelcamino, on Flickr
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
    12. #52
      Jun 2006
      NW burbs IL
      Somebody's enjoying retirement, looks awsome Herb and motivates me to get working on mine.
      Matt
    13. #53
      Sep 2015
      So whats the plan when you need to take the valve covers off or heads off?
    14. #54
      It looks Sweet Herb! This is going to be nimble!
    15. #55
      Oct 2016
      love that project ! really cool !
    16. #56
      Hildebran, NC
      How did I miss this!!
      Awesome build!!
    17. #57
      Oct 2015
      Kansas
      The car is looking great! Always been one of my favorites. Question for you, what headers were you running with the big block in the stock frame? I'm trying to find some that don't hang too low on a car with a fairly low stance. Thank you
    18. #58
      Indiana
      Quote Originally Posted by Bow Tie 67 View Post
      Thanks Matt!
      - - - Updated - - -
      Quote Originally Posted by wyattroa View Post
      I'm not done cutting yet. I still have to cut out more firewall above the engine and on the sides. There will be room to work on it when I'm done. It won't be any worse than a 4th gen Camaro.
      - - - Updated - - -
      Thanks Wayne!
      - - - Updated - - -
      Quote Originally Posted by rchaskin View Post
      Awesome build!!
      Thanks Randy!
      - - - Updated - - -
      Quote Originally Posted by jmking9 View Post
      Thanks! I had a set of custom Stahl Headers but they've since shut down operations. I won't be able to use the Stahls with the new chassis, so if you're interested in them, I can send you some pics.
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
    19. #59
      Nov 2012
      Hi Herb,
      Random question: How did you acquire the skills to do all this crazy fab work?
      1972 Chevelle 6.0 LQ9/4l80e
    20. #60
      Indiana
      Quote Originally Posted by Smitty454 View Post
      Hi Herb,
      Not sure if I'd call myself a skilled fabricator. I read a lot, look at lots of pictures from real fabricators, and trial and error. So far, so good!
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
