      Southern California / Maryland
      Carb identification?
      Looking around but cant find much info on it - it is a Barry Grant style carb but it is a bit different --
      Primary / Secondary throttle blades are stamped 1.75" - double pumper style carb with down legs but blue venturi tubes... is this colored for being alcohol use or ? No serial numbers that I see anywhere
      1966 Chevrolet Chevelle 300 Deluxe 350 / 350 auto
      1968 Dodge Charger SRT8 6.1L Hemi / 6-speed
      1964 Dodge Polara 8-71 Blown 440 / 4-speed
      1998 Toyota 4Runner SR5 3.4L / 5-speed
      2013 Dodge Challenger R/T 5.7L Hemi / 6-speed
      Jun 2006
      Katy,TX
      Do the venturi tubes look like they come out? Meaning you can see a slight lip to the rest of the main body. BG/Demon had one carb you could swap venturi sleeves in to make it different CFM. You pulled off he baseplate to swap them out.It also had removeable boosters to swap between annulars and downlegs.
      Unfortunately the replacement parts are no longer av available.
      1965 GTO project car
      2004 Pulse Red GTO
      Jul 2016
      That is most likely a RS Race Demon. They come in drag, blower, oval track, road race and general competition. The sleeves are removable and the blue is 825 cfm. Red is 775, green is 675, gold 975, black 1025. I have a road race RS with 775 cfm sleeves and like it. Some don't care for Demon carbs. While they share similar parts with other 4150 style carbs the flow characteristics seem to be different. Wet flow vs dry. I can send you some specs of these carbs if you PM me with your email. You can likely identify it based on bleed and emulsion sizes etc.
      1986 Saleen, Aluminum block 408W, T56, Full Griggs Racing supension
      appears to have removable venturi tubes... so is thig worth anything? im not a big carb guy - most of my cars are going EFI so... no real need for it
