Thread: SBC 4 & 7 Firing Order Swap
11-28-2005 #1
Anyone have any experience with swapping the #4 and #7 firing order. I'm just wondering if there is any difference in power? I was looking at cams online today and didn't know they even did this. Anyhow, I thought maybe it helps the exhaust scavenging by trying to even out the exhaust pulses.
12-01-2005 #2
- Apr 2005
- 90
supposed to make the engine run smoother.
pretty much a ploy by the cam companies to get people buy a new cam, same as conical valve springs.
12-13-2005 #3
Starting The Transformation
- Nov 2005
- 130
WEll unless you have tested both the conical valve springs and 4/7 swap on a engine dyno I hope you keep believing that.
If you really want to learn a lot about the 4/7 swap this is a good read
http://speedtalk.com/forum/viewtopic...light=cam+swap
If you want to learn about conical valve springs, I'm more than happy to educate anyone on them.
BretBauer Racing Engines
Specializing in late model GM motors
1964 GTO (work in progress for 13 years)
600 HP 365 cube SBC
C5 Front Suspension
Satchel Link Rear
T56
Not gettin done anytime soon
2000 Camaro SS SCCA FS Car
Koni Adjustables
35mm Front Bar
DOT Race tires....
