      Jul 2016
      LS3 GMPP Bulkhead connection for gauges
      Anyone using the GMPP bulkhead connection for your gauges ?? I'm using NVU gauges and they came with an oil sending unit and coolant temp sender. I could add an additional coolant temp sender in the pass head NBD, however I was wondering about the oil pressure sending unit ? The sending unit supplied may not fit where the original LS3 GM sending unit is installed. I would like to use the bulkhead connector for the oil pressure. Thx!
      Feb 2011
      dallas, tx
      Bulkhead would be used for odb style gauges. I'm using rpm, speedometer only from the bulkhead. Oil pressure I had to use a adapter on the side of the filter housing
      You can use the Dakota Digital gauges that get oil pressure (and water, tach, etc.) from the OBD wires. No additional sending units required...
      Attachment 114845
      ​John Parsons
      Jul 2016
      Thanks guys.
      Jacksonville, FL
      I am using the oil pressure signal from the bulkhead connector on my car. It sends a a CAN type signal through the Dakota Digital HDX control panel. If you are able to select Can signal input on your gauges, then you should be able to use it.
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
