      Sep 2016
      LA - Lower Alabama
      Bowler Trans Tunnel
      Does anyone know of a thread or install video for the Bowler transmission tunnel patch. I’m
      getting close to pulling my old small block and I’ll be putting in an LS2 with a T56 Magnum. I’m expecting to have to do some tunnel surgery for the Magnum and I went ahead and bought the patch. Having never done this before, it would be helpful to get an idea of what is involved.
      Thanks in advance.
      I did find one thread with three pics, but it’s much help.
      https://www.pro-touring.com/threads/...on-from-bowler
      Sep 2016
      LA - Lower Alabama
      Alright, I'm getting closer and closer to putting my LS2 in the car for the first time (I'm working on the oil pan swap now). There's really not a lot of info on this on the web. I did email Craig at Bowler, and he sent me the DSE pics for reference.
      Name:  67-69 Camaro Transmission Tunnel.JPG
      Name:  67 - 69 Camaro Tunnel Upper patch Installed.jpg
      For now, my plan is to lay the patch on top of my trans tunnel. Get it aligned like I want and roughly mark where it sits. I'll cut out the bulk of tunnel that needs to come out, leaving a couple inches extra above my mark. Put the patch back in and get it aligned again, then run some sheet metal screws into the lip I left to hold it in place. I hope I can cut along the edge of the patch about 6"-12" at a time. I'll try to make sure I either cut right at the edge, or cut through both the patch and the existing tunnel. I can peel back the lip from under the car, and put a couple tacks down to hold the tunnel where I've made my cut. When I'm done, everything should line up just right, and I can come back and finish welding and grinding.
      Thoughts?
      Pensacola, FL
      I have used the Alston chassisworks 1st gen tunnel cap. It fit nicely, has a stepped flange, and was fairly easy to install.
      https://www.cachassisworks.com/cac_p...ansTunnel.html
      Sep 2016
      LA - Lower Alabama
      It looks like DSE did some massaging to the Bowler tunnel patch. These are the patches I got from Bowler. The short panel is not shaped the same as the the one shown in the DSE pictures and the longer panel looks like DSE put a bend in it.
      I was hoping I would be able figure out where to put the panels without having to put the T56 in the car.
