      1968 Camaro Pro Touring
      Indianapolis, IN
      Price$58,000
      Contact: Brian ([email protected] 317-418-8870)
      I have decided to sell my 1968 Camaro. I bought it as it had a very straight body and I had always wanted to do a restoration on a first generation Camaro. I ended up going much further into the restoration with it ending up more of a Resto-Mod or Pro-Touring build. It took about 2 ½ years of work to get it where it is now. The car only has about 2300 miles on it since the project was completed. Either way it was a great build and I have enjoyed it but it is time to move on. Here are the details:
      Suspension / Steering
      Front Dampers/Springs: QA1 Coil Over
      Rear Dampers/Springs: Pro-Shock dampers with Hotchkiss leaf springs; damper
      mounting points moved inboard for more tire clearance
      Quick ratio power steering box with KRC pump
      Hotchkiss Anti-Rollbar (Front/Rear)
      Rear suspension Caltracs system to reduce wheel hop
      Brakes
      Baer Brakes: Baer Track Brake System with 13” front and rear rotors
      Engine
      Long Block
      Block: 1974-454ci bored to 4.31” (496ci) -Block Ht 9.780”-
      Crank: Eagle Forged 4340 (45442506385-CCW) Internal Balance
      Rods: Eagle “ESP” H-Beam CRS63853D (6.385”)
      Pistons: SRP Forged 142980 4.310” (8.5:1)
      Cam: Comp Cams 11-414-8 (grind CB NX298HR-13) Gross Lift .566/.575, Duration @ .050” 242/254,
      Lobe Seperation 113.0 degree
      Lifters: Comp Cams Hydraulic Roller Retro Fit (854-16)
      Pushrods: Comp Cams (Intake-7813, Exhaust-7814)
      Rockers: Harland Sharp
      Heads: AFR 325 CNC Bowls (X2101-F) Intake 2.30” Exhaust 1.88” (springs 924-16)
      Head Gaskets: Cometic 4.375” .040” (C5329-040)
      Fuel Delivery
      EFI System: Big Stuff 3 Base System with DAI
      Intake: Accel Pro Ram Rectangle Port (74202D)
      Throttle Body: Wilson 100 deg Elbow with 90mm throttle body (471090)
      Injectors: Siemens 3105 Low Impedance 83#/hr
      Fuel Lines: SS tube .50” x .035”
      fuel pump: Aeromotive A1000
      Fuel Pump Speed Controller: Aeromotive 16306 Billet Fuel Pump Speed Controller
      Fuel Pump Regulator: Magnafuel Pro Star EFI Regulator MP-9950B
      Fuel Filters: Aeromotive Pre filter 100 micron (12304) and 10 micron (12301)
      Fuel Cooling System: Setrab Oil Cooler with fan
      Ignition
      Distributor: MSD 2345 Cam Sync with phased rotor
      Ignition Control: MSD 6BTM
      Ignition Timing Settings: Variable timing controlled by ECU
      Air Delivery
      Super Charger: Procharger D1SC with Carbinite Pro-Grip pulley coating
      Boost Surge Control: Procharger ProFlo Surge Valve
      Cooling System
      Radiator: C&R custom radiator
      Water Pump: CSR Billet Electric (CSR900N)
      Surge Tank: C&R Surge Tank w/ sight tube
      Fan: Spal Dual 11” 2800 CFM
      Exhaust
      Hooker Headers with X-Pipes
      Flowmaster Mufflers
      Transmission / Rear End
      Tremec TKO600 (26 spline x 1 1/8”)
      McLeod aluminum flywheel with RTS Street Twin Clutch
      Moser Ford 9” with True Trac Limited Slip (3.50 ratio)
      Body / Paint
      Body taken down to bare metal with only minor bodywork required
      House of Kolor: Tangelo Orange (PBC32) with Snow White (PBC44) stripes
      Interior
      New clean carpet
      Summit Racing Sport Seats
      Stock Rear Seats
      Autometer gauges
      5” Speedometer and Tachometer installed in stock gauge bezel
      2 1/16” Fuel Level, Oil Press, Voltmeter, Water Temp, Boost Press installed in custom carbon
      dash
      Stereo: Alpine stereo, 2 x 10” subs, 2 x 6.5” and 2 x 5.25 speakers; 2 amps (850 & 550 watt)
      Custom console
      Electrical System
      The stock fuse box was used with custom wiring from the box in both directions throughout the car.
      A secondary fuse box was used for the fuel injection and support systems.
      Big Stuff 3 wiring harness is used for the main fuel injection system.
      Wheels / Tires
      Wheels: Intro Twisted Classic (Front – 8.0” x 17”, Rear – 9.5” x 17”)
      Tires: Front – Nitto NT555 P245 / 45 ZR17, Rear – Nitto NT01 P275 / 40 ZR17
      https://www.dropbox.com/s/b1dos5n276...artUp.mp4?dl=0
      (Keep in mind it takes a few seconds for the Dropbox link to load)
      I will include the laptop to program the fuel injection as well as help you understand how all of the programing works.
      $58,000
      Still for sale. $49,000
      Sold
