Thread: I Need a Fuel Pump Relay
11-07-2017 #1
- Sep 2016
- LA - Lower Alabama
- 560
I would like to put my fuel pump relay in the trunk with my battery and starter solenoid. Having never done an LS swap before, I'm not sure where to start with looking for a relay/harness. Can someone recommend a relay and a harness (I assume I need a harness for the relay to plug in to)? It looks like the relays with the PSI conversion harnesses are intended to be mounted in the block with all the fuses near the engine.
