    Results 1 to 9 of 9
    Thread: Dstroked LS2
      Mar 2012
      Dstroked LS2
      We built this as a classic DZ302 but with LS technology as a 331CI:
      • Seasoned LS2 block re-sleeved .10 over
      • CALLIES MAGNUM XL CRANKSHAFT: Part number apz39v-XL 3.185 Stroke
      • Callies Ultra Rods 6.350" @ 660
      • Cam is 054-62135-62744-111+3. This cam is 231/237 at .050, .622/.600 lift and it is cut on a 111 LSA with a 108 intake centerline.
      • Valve Springs are 73925K1
      • Pistons are JE forged flat top with a -3.0cc valve relief to achieve 11.8:1 compression ratio
      • Heads are Air Flow Research done by Jason Mamo – “Mongoose” – 205cc heads with a 53cc chamber
      • GM Parts 88958679 Front Distributor Drive Cover Kit
      • Holley 300-134 Dual carb intake.
      • FAST 305007 Dual-Sync Billet Distributor
      • 1803 500CFM Edelbrock carbs x2
      • Edelbrock sequential dual carb linkage.
      • Lunati Racing solid roller lifters
      • Brian Tooley Racing dual roller timing chain
      • Improved Racing oil baffles and oil pan with oil pan pick up.
      • Texas speed oil pump
      • Comp Cams pedastal roller 1.7 ratio rockers
      • Comp Cams hardened push rods
      • all ARP hardware
      9500 plus the ride. 600HP, classic lines and will rev to the heavens and back.Name:  11070191_10204648326741608_8741095733981680660_n.jpg
Size:  114.4 KBName:  10903921_10204570315552623_6786774386361089807_o.jpg
Size:  178.2 KBName:  1395306_10204256593388519_921005521828070133_n.jpg
Size:  53.6 KBName:  11011547_10204527665405150_2184988958952299407_n.jpg
Size:  77.2 KBName:  532957_10204295870410420_194462074588315549_n.jpg
Size:  75.8 KBName:  scoop.jpg
Size:  192.8 KBName:  1380134_10204653809678678_7182106927240203342_n.jpg
Size:  115.1 KBName:  10659004_10203313732778839_3459422857424976351_o.jpg
      Jan 2017
      pickering ontario canada
      Plus the ride? What do u mean.
      Any photos?
      1971 chevelle LSA 700hp -
      Apr 2017
      Quote Originally Posted by 1sikride View Post
      Any photos?
      think he means shipping
      Mar 2012
      PLus the ride means shipping.
      Pics in the first post.
      Apr 2016
      Dyno numbers by chance? Pretty neat setup!! Why are you not using this?
      Mar 2012
      We have not dyno'd it with the GMPP front cover, distributor or carbs. We'll get to using it, if it doesn't sell. I am thinking about an awd 32 Chevy on an all aluminum frame with Vette suspension and this motor... but right now, I hate seeing it sit.
      Jun 2012
      South Lyon, MI
      Cool motor. I would love to hear it run and see some dyno figures.
      Mar 2012
      Quote Originally Posted by cornfedbill View Post
      I'd love to sell it, so you can do that.
      If you add up the parts list, you'd see my asking price is about 66% of jobber cost, let alone retail.
      With the carbs and distributor, it's easy to retrofit and gain hellacious performance.
      Mar 2012
      bump... someone buy this before I build an all aluminum AWD corvette based chassis and put a 35 Chevy on it.
