Thread: '79 T/A Project Chronophage
- Oct 2017
- St. Louis
- 117
Project Chronophage (Greek for Time Eater)
I'm new here and wanted to share my project,
I purchase the car in 2011 and it looked pretty decent, I restored a set of 15x8 snowflakes to put on it, restored a set of tail lights etc but there were lots of stuff hidden under the surface. The front end just didn't quite line up and the fender was blue inside so it obviously took a hit at some time. A couple years ago I started to tear it apart just a little to clean the engine bay up and fix the fender. Well it quickly turned into a complete frame off. I found that the drivers lower control was bent and the subframe was off center. No wonder why things didn't line up right! I am really very happy with just how little rust is on it. Obviously not typical for a 2nd gen. I only have to replace some of the driver's floor. Even the usually rusted rear pan area is excellent.
I have been at odds on the path to take...keep the #s motor and restore back to stock or more of a pro touring setup. Last weekend I was able to score a great deal on Global west tubular upper and extended travel lower control arm, Viking coilovers, pro G-braces, Global West Cat 5 leafs and solid body mounts so I think my path is set....LS/6 speed pro touring it is. I plan on keeping it as stock looking as possible but make her handle and perform anything but stock.
I have a young family that takes a lot of my time, I tend to get sidetracked on occasion with other projects
I do not have the deepest of pockets and most of the products I will wind up buying will be second hand products to save a bunch of money. I have wrenched on cars my entire life but this will be the first major restoration. I plan on doing everything (95%) by myself including body and paint so I will be doing a lot of research and asking a WHOLE lot of questions. I will be here often for motivation and help staying focused
I'm going to see if I can learn how to add pics from flickr now that photobucket screwed everyone.
10-27-2017 #2
- Oct 2017
- St. Louis
- 117
10-27-2017 #3
- Oct 2017
- St. Louis
- 117
My first question is with the LS swap how will A/C and heat be run? I'm wanting to clean up and smooth the firewall so I need to know what needs to be left open to allow access to the interior.
10-28-2017 #4
