    Results 1 to 12 of 12
      Nov 2010
      Holley Injectors
      For sale are some used, but still good 48 lb/hr performance fuel injectors, set of 8 for max hp 765, part# 522-488. $100 shipped. Sorry, but I don't have any pics.
      Feb 2014
      Do you know if these are the same height as the Ls2 injectors? I'm currently running the fast lsxrt intake and fast rails, want to make sure they work. Thanks!
      Nov 2010
      body length on the Holley are 2.85" can't find anything yet on LS2 height
      Houston, TX
      Quote Originally Posted by Chuck0379 View Post
      Is that the length between the o-rings? If not, what is the distance between the o-rings, center to center?
      Thanks.
      Tu Ho
      Firebird V2-LS swap
      Nov 2010
      O-Ring to O-Ring is 2.415"
      - - - Updated - - -
      https://www.holley.com/products/fuel.../parts/522-488
      Oct 2011
      Tampa
      Quote Originally Posted by BlackHD View Post
      These are taller. If Your wiring harness is most likely set up for ev6 connectors, You will have to try and source adapters. These are ev1.
      Feb 2013
      South Carolina
      Quote Originally Posted by Corey R. View Post
      Pretty sure you meant to say "if your harness is set up for USCAR connectors, you will need a set of Amp connector pigtail adapters."
      EV6 injectors are produced with Amp, USCAR, and Sumitomo connector styles.
      Nov 2010
      Photos added
Size:  351.9 KBName:  79BE1CF9-230D-41AF-8C6A-524B2307FA00.jpg
      Nov 2010
      bump
      Nov 2011
      I'll take them. PM me your PayPal info.
      Nov 2010
      PM sent
      Nov 2010
      Sold.
