      Feb 2008
      Riddler 650 fitment
      Can someone please confirm these will fit my 67 Camaro? Currently has DSE upper/lower control arms, BMR 2" lowering springs and 2" lowered rear leaf sprigs. I'm also wondering if I should go with 17" or 18"? No racing just mountain cruising. Any input would be much appreciated.
      https://www.ridlerwheel.com/650-grey
      Nov 2002
      Georgetown,TX
      What width and backspacing are you asking about?
      Feb 2008
      I'm open to whatever will fit and fill up the wheel wells. Sorry if im being vague but I've never had to ordered wheels for a classic.
      Oct 2015
      Western Mass
      You'd probably be "safe" with 7" x 17" fronts and 8" x 17" rears if you want to keep the tire flush or just inside the fender lips. If you like them sticking out... you could go wider but it's not a great look. Also your drop figures in to the look. You could also go up to 18" but the sidewalls drop a little in height so the ride might be a little different. Sounds goofy, but if you figure out what the outside diameter of the tire you want to use (like 26.00") you can cut a piece of cardboard in a circle and see how it fills the wheel well, visualize the gap. Width is another animal, but I think many 67-68's are running something like a 245/45-17 or a 255/45-17 rear.
      '69 LeMans Blue Coupe, White Interior, Massaged .030" over 454, Super T10 4-Speed,
      Holley 4150, Pertronix Ignition, CompCams Xtreme Energy XS274S, 781 Oval Port Heads
