Thread: Oil Pan ??'s
11-25-2005 #1
Oil Pan ??'s
Hey guys! It has been awhile since my last post, but my stock oil pan on my Mark VI 502 has punctured a leak! What do you recomend for replacing it with something with better ground clearence? I know this has to have been a problem for some of you. I was looking at the Canton Road Race Pan. From what I can tell it has 1" more clearence but still retains the same amount of capacity. I would like it if I could get another 2" from stock pan depth, but I don't wanna lose any capacity if at all possible. My second question is if I get the Canton Pan, do I have to get a new pickup and oil pump? It says you have to get the required dipstick. But would it be smart to install the other two items while I'm in there? I am not the most knowlegable when it comes to things of this sort. They also have standard and high volume oil pumps. Which is better for an occasional strip and lots of street use car? Here is a link to the page of Canton pans for anyone willing to lend a helping hand! But I am willing to consider different pan options if there are better out there! Thanks guys!
http://www.cantonracingproducts.com/...bc_street.html
Justin
73 Nova, 502 ci, TKO600, Mosier Eng 12 bolt, 6 point roll cage, Wilwood rear discs, factory front discs, 250 HP nitrous, subframe connectors, Slide-a-link trac bars, 17" Boyd Coddington Smoothie II's, and Hotchkis TVS kit.
11-25-2005 #2Any takers?
Justin
11-26-2005 #3
Starting The Transformation
- Nov 2005
- 130
Novaguy,
The Canton pan is going to need a new oil pump pickup to match the pan AND oil pump. If they mention the new dipstick as well, if that concerns you then it's probably a good idea.
Canton pans are a good budget pan that will do what you need, and do a good job at it. I'm a fan of standard volume pumps, so keep the one you have just make sure you get the right pickup for it and TQ the oil pump stud down once it's installed.
As for pan capacity. I always use a 7qt pan with 5-6qts in it depending on drainback and use because there is power there. Especially in a motor with a longer stroke.
FWIW I use a lot of Canton Pans on Pro Touring type motors, they have a lot of applications and do a good job for the money.
BretBauer Racing Engines
Specializing in late model GM motors
1964 GTO (work in progress for 13 years)
600 HP 365 cube SBC
C5 Front Suspension
Satchel Link Rear
T56
Not gettin done anytime soon
2000 Camaro SS SCCA FS Car
Koni Adjustables
35mm Front Bar
DOT Race tires....
