    Results 1 to 17 of 17
    Thread: ZL1 Brakes
      May 2008
      Chicago
      ZL1 Brakes
      So I am going to start the build on my 69 Camaro, I wanted to put ZL1 Brakes all the way around on it. Can someone tell me if they have done this and if so what did they use as far as spindles and brackets.
      May 2008
      Chicago
      I believe I found it on Google. It seems to be relatively cheap for the brackets. Looks like you can do everything for under 2000
      Nov 2002
      Georgetown,TX
      Got a link?
      May 2008
      Chicago
      Aug 2015
      charlotte
      I used lsxconcepts.com, they also have this setup, you will also need large wheels! I have the standard SS brembos and I have less than 1/4" gap between caliper and the inside of my 18" wheels
      May 2008
      Chicago
      Quote Originally Posted by slimjim View Post
      I planned on using 18 inch wheels, is that big enough?
      Loganville, GA
      The ZL1 rotor is .4" larger than the SS rotor, so the 18 inch wheels may not clear, especially since Jim says he only has .25" clearance. It will depend on the wheel and how it is made.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      Aug 2015
      charlotte
      I may upgrade in the future if it will fit, But I'm skeptical at this point, these are boze 18" with big brake clearance.
      May 2008
      Chicago
      Looks like I will have to place a call to Forgeline and ask before I commit.
      Apr 2010
      Portland, OR
      SS brembos are nice and I believe fit 18 inch wheels. Should mount the same as zl1s I just swapped mine.. On the street it feels the same.
      1973 Firebird 466 Pontiac, T56, C5 Brakes, PTFB and Hotchkis suspension
      2011 Camaro SS Supercharged, ZL1 body and brakes, Z28 suspension.
      May 2008
      Chicago
      Quote Originally Posted by 70Uglybird View Post
      That's what I want to hear
      Jun 2017
      york pa
      I have the lsxconcepts brackets love them fit great. I used camaro ss brembos also but not all 18" wheels fit my xxr wheels didnt
      Nov 2002
      Georgetown,TX
      Quote Originally Posted by lsa1stgen View Post
      What did you use for front wheels?
      Jun 2017
      york pa
      xxr wheels would not fit front or back had to mod the calipers looking back now wish i wouldnt of done that and just got different wheels
      Jan 2009
      Hermosa Beach, CA
      This is a noble cause. Please let us know how it goes. Anyone have pics of the ZL1 brakes? Do they say Camaro?
      Pete
      1968 Camaro
      2009 Porsche 911 Carrera S
      http://www.cardomain.com/ride/2543199
      Loganville, GA
      The ZL1 calipers are black with ZL1 on them and Brembo below that. Picture here: http://www.chevyhardcore.com/tech-st...-track-camaro/
      1975 MGB Roadster
      2003 GSX750F Katana
      Feb 2018
      To anyone running the SS/CTS-V brakes. What brand and bore size master are you running. Thanks
