    Page 1 of 8 1 2 3 4 5 6 ... LastLast
    Results 1 to 20 of 149
      Feb 2015
      Ghiamonster -- A little something to pick on the big boys with -- --
      Jun 2012
      Upstate SC
      Very nice! Was this car featured in VW Trends years ago? There was a white Ghia with window tabs featured back in the 90's that always stuck with me.
      Jun 2011
      SoCal
      OMG.....subscribed
      My first car was a '58, bought it when I was 12 for $100
      -J
      www.totalcostinvolved.com
      Feb 2015
      Quote Originally Posted by Sales-TCI-Eng View Post
      OMG.....subscribed
      -J
      I hope to keep you entertained with my journey
      Quote Originally Posted by theastronaut View Post
      Yep Same car -- I bought from original owner about 3 years ago -- It had been setting for about 10 years while he went open wheel racing -- I originally was going to remove the tabs as I brought this back to street car form, but after looking at it over the course of the redo, they grew on me to the point that I've left them and really like the 'look'.
      I've been trying to find that issue of VW Trends for quite a while, can't even find out which issue it was ---- -- --
      Appreciate any help finding a copy of that magazine.....
      Only the body and cage are the same as when I got it -- -- Everything has been updated, new and improved -- -- I now got over 300HP to the rear wheels -- instantly blew up the Porsche trans that came with it -- I've been chasing the 'next' piece to break as I continue to sort this puppy out
      Nov 2013
      This is so cool.
      1997 Chevrolet C1500 LSX powered full autocross build
      Jun 2012
      Upstate SC
      Sweet! In for updates!
      Feb 2015
      That is so cool -- -- what month and year is that issue???
      Pretty Please, can I offer to buy that from You?????
      Feb 2015
      Jun 2012
      Upstate SC
      Quote Originally Posted by Ghiaguy View Post
      Glad I was able to find it! Been getting VW mags since I was around 9-10 years old so it was one if the earliest I have, I'm 27 now. I'd rather not let mine go but this guy has one here:
      http://www.thesamba.com/vw/classifie...php?id=1336275
      Feb 2015
      What month / year is the issue????? -- -- finally found it Aug '97 thanks
      Put up a picture of your VW -- I was just checking out your truck build -- it is cool
      Aug 2011
      North Platte,NE
      That is about 10 shades of badass right there....
      Jun 2012
      Upstate SC
      Thanks! Mag is from August of '97, VW Trends. The VW is an original paint '64 sunroof. Has a 90 hp 1679cc that broke a valve spring at the end of last year. Going back with better heads, bigger cam, etc and hoping to make 140 hp and get into the mid 8's in the 1/8th mile. Buying up parts for a ~210 hp 2276cc stroker as well. I've built some wider 356 style wheels for it and have slowly been setting it up for autocross. Hope to get it going soon.
      Feb 2015
      That's nice bug -- Go turbo!!! milder engine more HP -- Come to the dark side we have Cookies LOL
      I built a '60 Fiat 600 in '08 -- -- I was able to get some get over 275HP at the wheels with a 2165 on 15pounds boost,,, and the torque is off the charts -- --
      Feb 2015
      Today's 30 minute project -- -- Get the new Cam Sensor installed -- What a PITA!!!!!! -- -- everything that could screw up did.... Finally went and got my Engine Guru and between the two of us we were able to get the Distributor drive in,,,, it fought us all the way... the sensor dropped right in after that -- Looks good in there now -- 5 hours later LMAO
      Jan 2015
      Charlotte, NC
      the phone-dials looks dope on there
      Feb 2015
      Thanks -- I had bought some hubs that were drilled for either Chevy or Porsche patterns and was actually thinking about going with Chevy rims as I've got a ton of friends that do the bow tie thing and I thought I might be able to get some castoffs from them -- -- But was cruising CL one day when these 16" Phone-dials popped up and they were listed for almost nothing and they had good roll around rubber on them AND they were about 10 miles from the house -- SLAM DUNK to me LOL -- And like you said, once I saw them on there, just knew they fit the car................
      Just been having a little trouble getting tires that are small enough to fit under the fenders and have sticky enough rubber -- current have some 225/55 Yokohama s-drives with 240 TW and they tend to slide around a bit under power -- the next step is tubing the rear and going coil overs -- that project is skeering me LOL -- So I'll try this setup out for a while and enjoy it!!
      Nov 2009
      Manitoba, Canada
      That's a cool little car, keeping an eye on this.
      Evan
      Feb 2015
      Getting ready to button this rebuild up --- so did a quick tear down to add a couple of pieces of bling and show off the engine...... I only pealed off the sheet metal and put on a new fan shroud today -- -- I have one word of warning, have all your stuff powder coated at one time and not 4 months apart like I did -- you'll see why LOL
      First off this engine is a 2989cc toy -- It is 90mm stroke by 104mm (.030 over 4") It was constructed using SBC chevy pistons and rods and the crank was ground to accept small journal chevy rods -- It also uses APRM custom Siamese barrels, These are over 40 years old and pretty much made of unobtainium, as well as the ARPM case that everything bolts to. The engine is topped off with a rare set of angle port heads with 50 int 40 ext valves in it,, (they have just started offering repops of this head).. I'll pop up a couple of pictures so you can see the very different setup, stud pattern, and how close the sleeves are together (OK they are touching)
      AND Finally -- -- all back together -- what a crappy picture, taken at night -- need a better one tomorrow
      Jan 2015
      Charlotte, NC
      cant you get 205/45/16 in sticky rubber
