    Results 1 to 1 of 1
      Mar 2015
      86 D150 wheel options
      I just purchased a 86 Dodge d150 short bed for $600. It needs work. I plan to make a daily street rod out of it. A problem I have is the 5.5 on bolt pattern. Not many options out there for street trucks that don't look trashy. There is torque thrusts wheels but sizes are limited. I want a 17x9 or 10 in the rear and 8 in width in the front. I want more of a classic look. The 72-78 trucks had 4.5x5 bolt pattern. Would the older spindles fit the newer trucks? Or can I just put the older rotor hub assembly on the newer spindle? They have a lot in common. The rear end is easy to fix. I'd also like bigger brakes. Any ideas?
