    Results 1 to 10 of 10
      Jun 2010
      Deployed
      Tuning LS7, what to do?
      Need my LS7 tuned because of the mods. Problem is who to take it to. Nobody in Las Vegas will do a start up tune and the one people reccomend is $900. I see better known names like Frost is only $550. What do the expert on this side of the country take their cars to?
      1970 Camaro/DSE build
      Las Vegas, NV
      Who did you contact here in town?
      There are only a couple that I recommend
      What pcm are you running? E38 ?
      What mods?, I don't recall that you had anything very drastic, just a cam swap
      Jun 2010
      Deployed
      Leading Edge Perfornance, I have the E67 ECM. I did a cam swap and had the heads CNC ported and upped the injector size to 65lbs. Other then that, long tube header, 3" exhaust, intake
      Las Vegas, NV
      Yeah, I wouldn't go to that shop at all
      what size cam? 65# injectors may be overkill for it ( stock injectors are 42#)
      All LS7 had the cnc ported heads
      Stock intake/ (they perform well)
      I can get you in contact with a couple good guys here in town
      Does the E67 still have stock tune? or VATS removed , etc?
      Jun 2010
      Deployed
      I ended up using the GM performance harness and ECM. It's already configured as a stand alone without VATs and emissions. It does have the stock LS7 tune on it. The heads were checked over by Texas Speed and they did the PRC 265 program to them. The cam is their Stage 2. They recommended the 65lb injectors since I needed new ones anyways.
      Feb 2011
      dallas, tx
      Base tune wont keep it running ?
      Jun 2010
      Deployed
      Quote Originally Posted by icemanrd19 View Post
      I didn't even dare to try and start it knowing I modified the engine.....Could I?
      Las Vegas, NV
      Yes, you can start it
      It isn't highly modifed, just a mild cam and larger injectors
      You did measure both for correct pushrod length and PTV clearances, correct?
      Jun 2010
      Deployed
      Interesting, who would you suggest around here?
      Las Vegas, NV
      [QUOTE=badazz81z28;1239459]Interesting, who would you suggest around here?[/QUOTE
      Send me a text and I will forward you a couple guys here in town for tuning
      (702)677-4085
