      May 2007
      Chicago, IL.
      LS Serpentine System
      The LS platform is raising the bar in muscle car performance and keeping pace with this new standard is Billet Specialties Top Mount LS Tru Trac. The top mount LS kit is engineered to clear cross members and steering boxes in most muscle cars while keeping a tight profile to the engine block. This all in one box kit includes a crank damper from ATI and the all new Edelbrock LS water pump. Standard high performance components include a Powermaster alternator and Sanden AC compressor while Billet Specialties brackets and pulleys keep it all spinning in style under constant tension of our proprietary billet aluminum belt tensioner.
      Tru Trac Systems For LS1 2 3 6 Chevy (Top Mount) Include:
      • Polished Powermaster 140 amp 1-wire alternator
      • Billet aluminum 1pc. alternator fan & pulley
      • Natural finish Edelbrock LS water pump
      • Billet aluminum water pump pulley
      • Billet aluminum bridge bracket
      • Patent-pending billet aluminum tensioner engineered specifically for the Tru Trac system
      • Billet aluminum tensioner pulley
      • ATI Super Damper for LS
      • Billet aluminum crankshaft pulley
      • Polished ARP 12-point stainless steel fasteners
      • Goodyear Gatorback serpentine belt
      • Comprehensive installation manual
      Kits with AC include:
      • Polished Sanden SD-7 compressor
      • Billet AC compressor clutch cover
      • Patented billet compressor manifold
      Kits with Power Steering include:
      • Natural finish Maval Mfg. power steering pump with AN fittings
      • Billet aluminum power steering pulley
      Note: Tru Trac systems are not designed for use with hydroboost brake systems.
      Click here for more info: http://bit.ly/2vTGP38
      May 2007
      Chicago, IL.
      LS Tru Trac Images
Size:  16.1 KBName:  13450_C.jpg
      May 2007
      Chicago, IL.
      LS Tru Trac Video
      May 2007
      Chicago, IL.
      New LS Accessories from Billet Specialties
Size:  9.7 KBName:  LS-ThermostatHousings-Straight-POLandBLK.jpg
Size:  10.0 KBName:  LS-MODULARVALVECOVER-POLANDBLK.jpg
      Lawrenceburg, TN
      I like the new valve cover coil mount, nicely done
      bowling green,ky
      will those work with ls1 coils?
      69 Camaro
      03 z06
      90 mustang coupe
