    Results 1 to 20 of 27
      Jan 2016
      Torrance, CA
      Help finding off-the-shelf wheels with +25 offset
      I'm trying to run 275 tires instead of 225 but can't find wheels with the same frontspacing in a 10" width. I need about a +25 offset or 6.5" BS.
      My '66 Tempest has quarters that go over the tire so I have no outside room there and of course don't want to have my front wheels bulge out from the fenders. There's plenty of room on the inside but nearly every 10" wide wheel with a 5x4.75 bolt pattern has near-zero offset.
      I've currently got 225/70r14's on (I think) 8" wide wheels. I'm trying to run 275/40r18 in front and r20 in back. With sidewall bulge, my current tires are 9.25" wide with 4.5" of backspacing, again, including sidewall bulge. By my math, that's 4.75" of frontspace so with a 10.8" tire, that's about 6". Add 1/4" for disc brakes+safety... tire calculator's 6.5"bs makes sense.
      While I could keep saving my pennies, I really don't want to spend $500+ per wheel when there are lots of good looking options out there for $150-200. Can anyone point out a frugal option I'm overlooking? Perhaps +50 offset wheels that I could use with spacers?
      Thanks!
      1966 Pontiac Tempest
      Two-door, no post. Fixing things one-by-one. Daily driven when it's not up on jackstands.
      UMI Stage 4 suspension. Manual Z06 brakes from Kore3. 275/40r18 and 275/40r19 rear. Currently building a Pontiac 400 stroker.
