    Results 1 to 18 of 18
      Houston, TX
      LS2 Accessory Brackets
      I am trying to put a part list together for a LS2 going into a 1969 Camaro. Do I have to spend the $1,800 for the Street & Performance kit or will factory brackets work? I know you can not mount the A/C without knotching the subframe.
      Thanks.
      Phillip
      Apr 2003
      chbg, pa
      did you go to LS1TECH.COM ? go over there and do a search , there is a conversion forum with many questions answered . I used street and performance's mounts and pan . no issues at all , and i am using them again for my next car .
      Mountain View, CA
      Just for referance, can an AC compressor be mounted in a 1st Gen chassis with an LSX?
      I'll go to LS1-tech when the time comes for the details, just looking for general info at this point.
      True T.
      My blog
      DT,
      Yes, it's been done. I believe the subframe had to be notched though.
      jp
      ​John Parsons
      Mountain View, CA
      Drat.
      True T.
      My blog
      Jul 2002
      Mesquite, TX
      True, I believe Tyler (or one of his folks) has announced that they've got a solution for AC in that case on its way.
      Dec 2002
      Lost Wages, Nevada
      Its in development, but no ETA as of yet.
      Apr 2003
      chbg, pa
      I did just hear that Vintage air is releasing something also
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by parsonsj
      DT,
      jp
      Yea, by BRP.. I don't like several things about that design.. one is pushing the motor too far forward and the other is the funky sway bar flip..
      AC is overated anyways ;)
      1968 Track Rat Camaro:
      Jun 2002
      Long Island, NY
      Quote Originally Posted by Steve1968LS2
      :icon996: Exactly-- if you get hot, just roll the windows down and drive faster.
      Nov 2000
      O-town
      Come live in FL for awhile you two yahoos
      Mountain View, CA
      I'd be inclined to agree with you on all but a few days. But, the wife-to-be sees things a little differently. AC probably wont be a part of the initial build but it will happen eventually.
      True T.
      My blog
      Jackson Ms
      it can be done but it is not a bolt in if you use the S&P style mounts.
      Chris V
      SOLD
      Dec 2002
      Lost Wages, Nevada
      Quote Originally Posted by Steve68
      Try Vegas........
      Nov 2000
      O-town
      Sorry Tom, forgot about the nice dry heat in Vegas and the High Desert of CA, When I was there in July it was only 108 on the lake bed, Nothing like the nice cool climate of Coastal CA,
      Sorry, Gotta have AIR!
      You should try www.synisterproducts.com They may have a solution.
      charleston, SC
      I had to notch my subframe for the compressor. I just received the bracket from Vintage Air to mount the Sanden compressor in the stock location. It's either that or using S & P's top mount set up that puts it up high on the passsenger's side.
      Robert's 1969 Camaro - 2002 LS1/T56, 10pt cage, Global West Stage III front suspension, HTH truck arm rear suspension, Sprint Cup 9" full-floating rear end, Fikse Mach V 17" up front 18" in the back and still working on it...
      Apr 2003
      chbg, pa
      scogin918 , I have to ask , what mounts are you using with the LS1? S&P's mounts require alot of clearancing of the subframe to get it to fit . I have the same bracket you speak of . I would be interested in seeing some of your work in this area.
